Cones vs Compression |
Post Reply | Page <12345 7> |
Author | ||||
Anna Recksiek
Registered User Suspended Joined: 24 February 2010 Location: Margate Status: Offline Points: 41 |
p audio has always been a good product Edited by Anna Recksiek - 24 February 2010 at 11:19pm |
Ben_Lawrance
Young Croc Joined: 12 January 2006 Location: Brighton Status: Offline Points: 919 |
Just to chuck my pennies in the jar, i would like to say that my mid/tops have an EV DH1A 2" compression driver x'd-over at 1.6KHz.
There is little eq in the Omnidrive and i think they sound so sweet. Hopefully Ceharden will back me up as he knows the boxes in question.
ArthurG
Young Croc Joined: 03 May 2004 Location: France - China Status: Offline Points: 976 |
FK1 uses a very special custom made driver manufactured by FANE which is a far cousin of Studio 5 FR
ArthurG
+1000 Heat treated Aluminum diaphragms sounds very smooth For Beyma, I like the sound of the new CD10 high tech polymer dome. A good step in the right direction
ArthurG
Sorry, but when you see the high failure rate of big power switching amps, this is the area of R&D people must focus now before thinking of already moving into more complex topologies... actually protections and reliability is the weakest point of these new monster switching amps and for example, I know a certain famous model with 80% failure rate in the field !!!
again, I disagree. SMPS is the weakest point of any switching amps as they are never enough powerful to keep up with the output stage (except some very few models like the ones from Andy). The proof is that usually, SMPS is only half, 1/3 or even 1/4 of the output stage power !!! And it's even more difficult when you have to make it with a PFC !!! Not an easy task at all to design a good reliable 8kw RMS SMPS with PFC. If it was so simple, all Chinese copycats will be king of the market now...
Lyndon A
Registered User Joined: 15 November 2004 Location: Bristol Status: Offline Points: 536 |
We use 6" Ciare driver then Selenium 1" that has a phenolic diagphram, sound quality is superb.
FSV Sounds
darkmatter
"but when you see the high failure rate of big power switching amps, this is the area of R&D people must focus now before thinking of already moving into more complex topologies... "
Completely agree. I'd guess that the current crop of Class D amps will only truly mature when the individual series/models mature. Seems there is such a high part count for some of these products and some very careful balancing acts in terms of planning tight tolerances, avoiding circuit resonances etc. that until experience shows where the weakest links are in a paticular circuit, reliability levels won't approach class A/B or G/H levels.
I've heard of manufacturers having to test individual parts to check where in the tolerance range they lie, and only using a certain set of parts together to avoid resonances etc., rather than throwing in a high quality tight tolerance part and knowing it'll work. That's sure to cause headaches for designers and repairers and will spell danger in terms of reliability.
haymere
Young Croc Joined: 28 December 2007 Location: Liverpuddle Status: Offline Points: 585 |
slightly ot but cannot find anyone that does horn manifolds like 2 or 4 1 inch comps onto a horn
_djk_
P-Audio
djk
Nitz V1505
Old Croc Joined: 16 September 2009 Location: UXBRIDGE Status: Offline Points: 1719 |
Could it be certain amps & compression drivers sound good together whilst others combos can sound harsh? CD's are generaly high spl low wattage affairs and it may be the case people are overpowering them. At the right x-over frequency and with the right amp combination I think CD's are fine and have good long throw capability.
& THE TOPS LIKE LIGHTNING..... |
Safetyman
Young Croc Joined: 08 February 2009 Location: Brighton, East Sussex Status: Offline Points: 555 |
....twin 32 amp Powecons with 10 mm cable in the workshop.....! |
Protect your hearing, and feel the music.
MU South East Roving Safety Rep. |
Safetyman
I asked a Brit manufacturer what was the difference between point source and line array last year. They gave the answer that( the system we were standing next to at the time in the warehouse ) whereas point source only required one top/top/mid @ £ 3,000 each, line array required 3 of these + a load of extra electronics to split the frequencies for a lot more profit !!
All depends, in my book, whether you like a 'wall of sound' or a better sound coming from one point ? I have not yet heard a line array that sounds half decent, as compared to a point source and none better than Tony's super tweeter in the Resolution series that took decades to develop, over compression drivers( mentioned earlier in this thread ). I am not that technically minded, but I can hear the difference. Maybe, if I had been brought up with line array, that I would prefer it ? Cheers. |
