confused question about sub DIY... |
Post Reply | Page <12 |
JonB67
You always in the same venue? Always set up the same?
Heard a different rig in the same space? Wondering if the room and speaker position might not be helping. Can you stack the subs in a corner and put the tops on stands? This eliminates the distance between the subs causing cancellations and will increase their effective output. While 200 people on your current gear seems like quite an ask its worth making sure you're maximising what you have before deciding how much more you need!
ALt
Registered User Joined: 20 September 2018 Location: Birmingham, UK Status: Offline Points: 20 |
hi,
No we do various pubs and room, just realised I typed 199 odd people, should have been 100! Doing sound for an indie band in a couple of weeks and will try stacking subs together. They are reflex cabs, checked phase, they are in phase and I'll post pictures on internals shortly... Cheers, Al |
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
I would say compact reflex subs are the answer ,they do everything you need, I use some Q15 designed by the late great tony wilkes ,plans available from member bee on here
there small and if loaded with the correct bms drivers they don't half go some
GOD TOLD ME TO DO IT !!!!!
JonB67
and not much bigger than yours.
I run the same drivers, bms 15n630 in a 90 litre box tuned to 43hz (manufacturers recommended spec)Get a decent amp behind them and they'll punch pretty hard.
