  New Posts New Posts RSS Feed - cost to build a porn horn
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2008 at 9:54pm
i wonder whether they factory built one comes with fly ware?
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2008 at 5:06am
I would think not, although if the cabs are coming from the same production house as the Stasys 3, I would think the cost of getting it added may be less than doing it for yourself (if they 'could' provide with flyware)
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2008 at 5:34am
No need to fly porns really, I only see them as a one a side mid/top solution. If your rig is bigger than that then you probably want a different cab.
Edit: Or multiples thereof!
Edited by odc04r - 30 November 2008 at 5:36am
sKs01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sKs01 Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2009 at 6:12pm
getting back on to this as Ive just realized i already own the compression drivers, at a push could you use these two a side, as my other option realistically is an mt12" section which to my eyes has a very similar problem of not having enough length to control dispersion enough to array. any thoughts?
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2009 at 6:38pm
http://www.speakerplans.com/forum/forum_posts.asp?TID=2179&PN=485
if you look at the comments here then two or three a side should sound wicked check this out
http://www.speakerplans.com/forum/forum_posts.asp?TID=13903
I Want a couple a GREY ONE'SBig%20smile. Will have to import thoughDead. Don't have d bucks for the RED ONE'sCry.
img225/893/1234545564564ym5.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote sKs01 Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2009 at 7:24pm
is that in reference to porns or staysis Francis?
i last properly looked at the porns in the summer and baught the beyma's other side of Christmas. looking at the polars they really are rather wide coverage but with an added few db and clarity over the mt12" flare and already owning one of the more expensive components to this their seeming like a sensible option when cash can be found for the upgrade.
having said that looking at the horn design between the staysis and the porn i cant see a great deal of difference and the staysis definatley array nicley... confusing or am i seeing things in the wrong light?
