  New Posts New Posts RSS Feed - Could the 186 be narrowed? (smaller driver)
binkstir View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote binkstir Quote  Post ReplyReply Direct Link To This Post Topic: Could the 186 be narrowed? (smaller driver)
    Posted: 25 October 2010 at 3:39pm
24 inches is a little wide for my living room and I'd like to have a bass horn. I was wondering if I could take this plan and narrow it to maybe 18 inches and use a 12" in it instead.
JDCutta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDCutta Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2010 at 4:43pm
Changing the width will affect the response from the cab, What driver do you intend to put in it, as this will have a major effect on response aswell?
If its for your living I would look into other options available ;)
djyves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2010 at 5:33pm
this guy changed the with from 636mm to 536mm
Edited by djyves - 25 October 2010 at 5:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote binkstir Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2010 at 7:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote binkstir Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2010 at 7:54pm
Thanks Djy for the link... cool build page.
I guess my thinking there should be some kind of horn design that would work with a 12 inch speaker.
subbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote subbass Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2010 at 8:01pm
http://www.freespeakerplans.com/plans.html
take a look at some of these
Post Options Post Options   Thanks (0) Thanks(0)   Quote binkstir Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2010 at 1:44am
Wow, lots of cool stuff, thanks!
Wrighty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2010 at 11:28am
If you're after a horn for a 12" driver, look at the Punisher. You need to use the Ciare driver which it's designed for though. That Eminence won't cut it.
ALL YOUR BASS ARE BELONG TO US.
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2010 at 11:35am
then have a RLH (BLH) instead of a FLH, or even a TH
you could design a nice cab for a 12'' driver
Edited by mykey- - 26 October 2010 at 11:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDCutta Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2010 at 12:13pm
You could also have a look into some of the designs from Billfitzmaurice.com
The plans are cheap, and are based around some cheap eminence drivers, if it is for the living room TV/Movies/Music I'd go for the THT which can be built slim.
There is also some good tapped horn designs over on diyaudio.com in the subwoofer section. Jbell has a single sheet plan, that uese the eminence 3015lf,
Don Synder has a tapped horn design for the Lab 12 - http://www.diyaudio.com/forums/subwoofers/143714-lab12-tapped-horn.html
And Lil mike has plans for a 6'5" driver
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDCutta Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2010 at 12:16pm
Lil mikes tapped horn - http://www.avsforum.com/avs-vb/showthread.php?t=1238398
Jbells single sheet tapped horn  http://www.diyaudio.com/forums/subwoofers/170771-single-sheet-th-challenge-6.html
Google is you friend ;)
t.geessounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2010 at 2:43pm
how about this one with a very cheep driver
