  New Posts New Posts RSS Feed - Crest 10001
Crest 10001
 Post Reply Post Reply Page  <1234 6>
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2018 at 10:20pm
Another useless post, but slightly relevant and a little bit amusing nonetheless; I've got a pair of Alto mac 2.4's, both of them have always tripped breakers on power up (well, one of them does, the other died a while back), One afternoon a few years ago I was setting up in a local pub during a six nations rugby match, when I switched the amp on I promptly found out that the projector and sky box were also on the same ring as the sockets on the stage and I had to walk through a not very happy pile of pissed up rugby fans to reset the breaker, it then took nearly five minutes for the projector and sky box to fire back into life.....Ouch
ReubGold View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ReubGold Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2018 at 11:12pm
Thanks guys.
It's the venue breakers, that trip.
If anyone can recommend Crest '01 series expert, I'll take in for a service.
If he turns me into a zombie, first person I'm coming after is you.
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2018 at 11:30pm
Must admit I've never worked on a 10001 but I've replaced the soft start on a 9001 which does have primary side inrush reduction (still a massive current spike).  I'm surprised the 10001 doesn't use the same scheme.
You could always implement what I do on the workbench.  100W lamp series with the live with a switch to short across it.  Start the amp with the lamp inline for a couple of seconds then flick the switch to give it full power.
bcs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcs Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2018 at 5:55am
It happen to me a few times as well using a crest cks1600-2. Agree with Njw as I also encountered the problem of switching other stuff off to.owners of venue not too happy with me.
simonp1100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simonp1100 Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2018 at 8:04am
Originally posted by simonp1100 simonp1100 wrote:
Hi,
The soft start on these amplifiers are pretty weird. It is done on the secondary side of the transformer BEFORE the AC is rectified rather than the usual primary side of the transformer via two relays and two 25 Watt resistors.
Check the two soft start relays (RL1 & RL2) & that the contacts have not welded together on either one. You could also check the 25 Watt resistors (each one is in series from the bridge rectifier to the main storage capacitors) are not open circuit (R3 and R4 & should be 10 ohms at 25 Watts).
I had one amplifier where one 10 ohms 25 watts resistor was open circuit, and the relay contacts were welded together.
Get the soft start checked FIRST on the amplifier this will then confirm if there is a problem with the amplifier or not and then go from there. Clap
RC1 Sound System View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RC1 Sound System Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2018 at 11:42pm
Just in case anyone is in the market for these amps I have a couple of 10001 sat here. Was planning to have a play with them, but too many other priorities in life!
Beast of an amp - 7,500 watts per channel at 1 ohm, could continuous current dump on sub more than a rack full of Powersofts!
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2018 at 11:57pm
Price per amplifier please. Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote RC1 Sound System Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2018 at 8:02am
I've been told they're very rare and sought after and in good working order fetch around £2k each.
Both the amps I have need some attention to one channel, but I've just not had the time to service them, hence would let them go for about £2,000+VAT for the pair.  PM me if you would like more info.
Would like to keep them really, but just got so many other projects on that I can see them sitting gathering dust for ages, hence struggling to justify keeping them!
Cheers, Jon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2018 at 11:49am
Price too please John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2018 at 11:50am
You want to go halfs Luton?
concept-10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concept-10 Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2018 at 7:23am
That's a good price, I have a big welding job on at the moment that they could be used for
bcs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcs Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2018 at 5:03pm
I nearly shat myself when I saw the weight...63kg omg
