Crest 10004 |
Post Reply | Page 12> |
Author | |||
Agayu
Registered User Joined: 18 February 2019 Status: Offline Points: 46 |
Posted: 09 December 2019 at 5:49pm |
Hello,
We have the oppurtunity to buy a crest 10004 for a good price. Is there someone who has experience with this amp ? We would like to put two or four if possible hog scoops (void 1000) on one side (bridged 2800 watt so 1400 watt to each hog) and on the other side our kicks. If the specs are correct this would be a perfect amp for that... since the 10004 are basicly two crest 8001 i suppose their grate for our sub section. We also know that this amp is like 60 kg but we don't find that an issue. Any other downsides that we should be aware of ? Another configuration we can get for a good price is 2 x crest CA12 wich we also can bridge to 2800 watt @ 4 ohm each.. maybe better than the 10004 option ? Thanks a lot !
Edited by Agayu - 09 December 2019 at 6:31pm |
levyte357-
Hope you are not contemplating trying to use this amp off 13A domestic supply.
Agayu
Nope, but does it need a lot more power than two 8001's plugged in at the same time ? Since the 10004 got two sepperate power cables and is basicly 2 x 8001 in one cab ?
Thanks
Edited by Agayu - 09 December 2019 at 6:27pm |
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 816 |
I really dont get why you all bridge amps... And i dont know anyone here in Denmark who does it. Just get some bigger or more amps..
But on the other hand, nobody run mono stacks. All stereo :) With that said, the 1k4 should smack your hogs for good. So cant see any issues with that setup :)
Agayu
Hello,
Thanks for the info :) yeah we just had some info from other soundsystems here in Belgium so we tought to use them in bridge mode.. but maybe we try it without bridging them and play @ 8ohm. Than each sub gets like 720 watts wich could be oke ! You know anything about the powersuply problems with this amp ? Thanks a lot !
levyte357-
Personally, I would suggest buying 2x amps, to power 4x cabs each. You will run into many problems trying to power that 10004. Bridged 8001s were OK, but Bridged Proline 3000s, will be more power, and even better tone. There is Void Inf8MK2 on FB right now, that will be plenty power for 2x Void V18-1000 per channel. If playing out regularly, I would recommend this. 10004 was intended to be install/statdium amp, hanging off dedicated 32A spur, not carted about from venue to venue, connected to mains supplies of varying stability. |
mattd
Old Croc Joined: 11 February 2006 Status: Offline Points: 1669 |
I guess it depends what a 'good price' is for the 10004 - if it's 300-500 quid then fair enough, but if we talking a 700-1000 I would look elsewhere..
Like Lev said the inf8 mark 2 is fairly cheap and gives a huge amount of power out. Saying that , it has one supply not 2 , we found we could get loads out if them before tripping breakers or fuses though.. I don't think you have an issue powering the 10004 as long as you have two sockets to plug it into..
Edited by mattd - 09 December 2019 at 8:32pm |
mk2_ginger_biscuit69
seems people often forget redundancy too....
using two amps means if you lose a channel, or even an entire amp, you can still limp on with half the rig, or less power. One amp doing everything means any fault and you lose a whole section of frequencies, mental. also, sharing the load on multiple amps means less stress on the electronics = longer life. |
Agayu
So the crest would be a great option then ?
Since i have 2 sperate power cables i don't think the power should be more a problem than two seperate power amps?
Risc_Terilia
Young Croc Joined: 15 December 2007 Status: Offline Points: 699 |
It's because a lot of people are hobbiest trying to save money - there's nothing wrong with that.
levyte357-
No, it's because if you bridge the right amps, you have uber headroom, and fully power drivers, without amplifier clipping.. I've not heard any amplifier, power 4x drivers, like a pair of QSC RMX 5050s in bridge.. But then, who wants to carry 60Kg of amplifiers to power 4x drivers !?
FOO
Sorry, i dont see any good reasons to bridge amps. But Maybe its just my sight on things.. need more power? Get more or bigger amps. Cost more, weighs more, takes up more space. But headroom is key...
