Crest 10004 |
Post Reply | Page <12 |
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
Foo, brisging doubles voltage swing compared to single channel operation
Earplug
Old Croc Joined: 03 January 2012 Location: Europe Status: Online Points: 7199 |
Yes, maybe - but never actually doubles the available power compared to just using normal (dual) operation, due to losses in the PSU, etc. when you bridge. And definitely adds stress to the O/P devices. Also, limits the number of drivers you can connect, ie unless it is a 'big boy' (ie expensive) amp, you will only be able to connect a couple of speakers (in parallel). Only well made/decent amps will allow 4 ohm bridging and even less 2 ohm. As Foo says, hardly worth the bother. Either get a bigger amp - or more sensitive drivers! |
