Crest Pro 200 low voltage problems. |
Mike Maki
Registered User Joined: 19 May 2008 Status: Offline Points: 15 |
Posted: 21 November 2017 at 11:27pm |
I have a Crest Pro 5200 that seems to have problems with low supply voltage.
I had problems with it power cycling at a gig so I put it on the bench, 1 channel driven into 6 ohms with 120v supply it will go all day. If I drop the supply voltage to about 107 v it will cut out with that load. It is the only Pro 200 series amp I own so I don't have another to compare it to but I am thinking it should be able to run on voltages lower then that. Anyone have some experience with these amps? Thanks |
kedwardsleisure
Supply range is 100-132V AC for the north american version which is is written in the manual, but I saved you the time by reading it for you.
North Staffordshire |
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5174 |
Once you go below 115 volts you are going to encounter abnormal behaviour. I am uncertain why you would want the amplifier to operate well on 107 volts.
Best Regards, |
