  New Posts New Posts RSS Feed - Crossover Design SOFTWARE
PavelP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PavelP Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2018 at 9:00am
Marjan is right. Software is good for beginners but it is very schematic and in the end the crossover you can design without measurements will be wrong.
Volnovod audio https://vk.com/kb_volnovod
Pasi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pasi Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2018 at 9:18am
Right software does it all for you. But they are not free or cheap.
Measurements in, accurate results out.
Xover itself rarely affects off-axis without affecting on-axis, but off-axis info is good to see for choosing your xover point to ensure smooth directivity pattern where horn cut off meets the LF nicely. Like when 15" driver gives you 60 degree beam, that's where you kick in your 60 degree horn.
