  New Posts New Posts RSS Feed - Crossover points for Superscoop
se.morales27 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se.morales27 Quote  Post ReplyReply Direct Link To This Post Topic: Crossover points for Superscoop
    Posted: 07 June 2018 at 6:25pm
Hi,
I have a pair of Superscoops on their way, which I'm gonna load with Void V18-1000. Just wanted to know if someone who's had experience with the same setup could give advice on what crossover points to use.
I have 2 HD15 for kicks.
The HPF is a 12 dB/oct Butterworth.
The LPF is a 24dB/oct Linkwitz-Riley.
The driver's spec sheet doesn't mention usable range as every other brand, just states the FS is 35Hz.
From what I've read of the FS it should be where the usable range starts without risk of overexcursion, isn't it?
But I've seen specs for other bass drivers and the usable range starts sometimes below and sometimes above the FS. So don't really understand how this works.
Also, according to this thread the usable range on the tested scoops is between 40Hz and 80Hz: https://forum.speakerplans.com/pd1850-vs-18soundlw2400_topic91285_page1.html?KW=scoop+graph
So right now I'm inclined to set a range of 40-80 for the scoops. And on the EQ:
-Put some boost on the 80 band
-12dB reduction on the  20 and 25 bands to protect from overexcursion. And a slighter reduction on 30?
Can anyone give some input on this? It's for a Reggae Sound System.
Thank you in advance. Appreciate any help.
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2018 at 12:12am
All depends on your taste  how you like it to sound,leave numbers out of it until you turn em upSmile
Some strictly reggae  sounds play their scoops high and prefer the sound, I personally would use the hd15s as low as they go and use that as a guide for lowpass. Hp 35 for a pairp 30 for four,again open to experiment.
_Natty_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2018 at 11:12am
yes man make some test and told us about what do u prefer :D
Post Options Post Options   Thanks (0) Thanks(0)   Quote se.morales27 Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2018 at 2:33am
Hey Sypa and Natty,
Thanks for the replies!
I understand your point on personal taste for the crossover between Scoop and kicks. However, for the HPF for the scoop I was wondering more from a driver safety point of view. Is 35 safe to operate? I can't find usable frequency figures for this driver anywhere, and I don't wanna risk over excursion.
Also, why would having more than 1 driver allow to change de HPF settings?
Thanks again if anyone has more input!
JBK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBK Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2018 at 9:30am
It's written on the plan
"Cutoff 38Hz, Use in groups of 4 for 30Hz Cutoff"
https://www.facebook.com/rootikalvibeshifi
King Simeon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote King Simeon Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2018 at 9:45am
When four scoops are played together they play as one speaker/horn & will play lower.
https://www.facebook.com/KingSimeonSound?ref=stream
https://soundcloud.com/king-simeon
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 11:21am
Originally posted by se.morales27 se.morales27 wrote:
Hey Sypa and Natty,
not such big problem for the lowest point I made test (by ears) on different cut-off from 30 to 40hz on super scoop loaded with drivers with an higher fs than the suggested one (pd1850 or void) but not big problems or unsafe behaivor, to me is much more dangeurs the hig parts.... ehy memba that im not so techinal so someone can tell you more!
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 12:24pm
I would never HPF Scoops at 30Hz.
But then again, I like them still working at the end of the night.
valve head777 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote valve head777 Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 1:33pm
when the cutoff is mentioned, the actual slope never is....
Or rarely anyway.
Edited by valve head777 - 11 July 2018 at 1:35pm
This page was generated in 0.102 seconds.
