  New Posts New Posts RSS Feed - Crossover points for Superscoop
se.morales27 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se.morales27 Quote  Post ReplyReply Direct Link To This Post Topic: Crossover points for Superscoop
    Posted: 07 June 2018 at 6:25pm
Hi,
I have a pair of Superscoops on their way, which I'm gonna load with Void V18-1000. Just wanted to know if someone who's had experience with the same setup could give advice on what crossover points to use.
I have 2 HD15 for kicks.
The HPF is a 12 dB/oct Butterworth.
The LPF is a 24dB/oct Linkwitz-Riley.
The driver's spec sheet doesn't mention usable range as every other brand, just states the FS is 35Hz.
From what I've read of the FS it should be where the usable range starts without risk of overexcursion, isn't it?
But I've seen specs for other bass drivers and the usable range starts sometimes below and sometimes above the FS. So don't really understand how this works.
Also, according to this thread the usable range on the tested scoops is between 40Hz and 80Hz: https://forum.speakerplans.com/pd1850-vs-18soundlw2400_topic91285_page1.html?KW=scoop+graph
So right now I'm inclined to set a range of 40-80 for the scoops. And on the EQ:
-Put some boost on the 80 band
-12dB reduction on the  20 and 25 bands to protect from overexcursion. And a slighter reduction on 30?
Can anyone give some input on this? It's for a Reggae Sound System.
Thank you in advance. Appreciate any help.
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2018 at 12:12am
All depends on your taste  how you like it to sound,leave numbers out of it until you turn em upSmile
Some strictly reggae  sounds play their scoops high and prefer the sound, I personally would use the hd15s as low as they go and use that as a guide for lowpass. Hp 35 for a pairp 30 for four,again open to experiment.
