crossover points |
Post Reply | Page 123> |
Author | ||||
ychole audio
Young Croc Joined: 18 January 2007 Location: United States Status: Offline Points: 625 |
Posted: 17 July 2017 at 6:19pm |
At what frequency can I cross between E140 and 2446H in a reflex box. How low can I comfortably cross the 2446h? I know its not suitable using the E140 at midbass but its all I have right now. I will be running them active. DSP will be on the ultradrive. We will be using them live and some recorded music.
Edited by ychole audio - 13 November 2017 at 6:55pm |
I am ZERIEL'S dad!!!
_djk_
Depends on your horn, 1Khz should be OK.
djk
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2537 |
Dub Specialist Sound
tbh Some ppl need to learn what the term of Loud Speaker acutly means, many many old drivers will play a wide bandwidth
with ease
Earplug
The E140 is a lovely driver. I had some stage monitors loaded with those and 2431 comps. No problem. |
ychole audio
My bad, I will run them active instead of passive. Horns are 2385a. Thank you for all the responses.
_djk_
Had a bunch of floor wedges with the E140, bi-amped them at 1.5Khz to a 1.4" throat Altec copy HF horn.
All the users really liked them. |
djk
RoadRunnersDust
Young Croc Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 561 |
With some notable exceptions, that statement is just straight-up wrong. The majority of instrument drivers are horrendous as PA drivers... |
Conanski
Nothin a little PEQ can't fix. |
_djk_
"The majority of instrument drivers are horrendous as PA drivers..."
Wrong in this instance, very fine below 1.5Khz, gets ratty about 3.5Khz. |
djk
RoadRunnersDust
I didn't realise the OP was talking about designing a Line Array... if your box needs that much EQ to be useable, you don't need DSP you need a chainsaw. |
RoadRunnersDust
Check the context of my post and compare it to your reply |
