Crossover |
Post Reply | Page 12> |
Visti
Registered User Joined: 15 February 2019 Location: Denmark Status: Offline Points: 66 |
Posted: 04 March 2019 at 7:52pm |
Just wondering what you would recommend. Buying a crossover or creating it myself.
Thanks in regards.
APC321
Young Croc Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 680 |
I think that you should buy an active crossover with very good limiters, especially if you will be using a 30Hz speaker at 20Hz.
Xoc1
Registered User Joined: 15 October 2012 Location: Devon UK Status: Offline Points: 397 |
Standard stock crossovers rarely work as expected. Firstly the crossover will probably be set to work with a nominal impedance of 8 ohms while the drivers will probably be nothing like that impedance at the crossover frequency. This can be compensated for by adding a zobel network (a resistor and capactor in series) added across the driver terminals that ensures that the crossover sees something like a 8 ohm impedance. Secondly the drivers may not match in efficiency and typically require a resistor network to attenuate the HF driver to match the output of the LF driver. The driver may also have resonant peaks or a natural roll off in its response that a stock crossover will not take any account of. So even if you buy a stock crossover it will probably still need some work to make it function as intended. If you have the skills it would be best designed from scratch
Visti
Thanks. I think I will try to design a crossover myself with a little help from a friend.
Earplug
A crossover for what? Bass - or mid/top? In any case, save yourself time & money and just buy a 3-way active. Inductor coils for passive crossovers aren´t cheap. You should be able to pick up a second-hand active for less than the price of the components for a 3-way passive. |
Visti
The answers don’t match. First says I shall make and second says buy. What do I have to do.
But thanks earplug
Earplug
I think that Xoc1 is talking about a passive crossover, where the stock units you can buy are a compromise and really need 'tuning' for the drivers you have. I am talking about an active (electronic) device - which is really far better. Have a read around about why! Even a cheapie like this: https://www.ebay.co.uk/itm/ProSound-Stereo-Active-Crossover/223191618038?hash=item33f741d1f6:g:GA0AAOSw9w1bxZ78 should be ok for party, etc use. Or: https://www.ebay.co.uk/itm/Citronic-CX34-Active-2-3-4-Way-Crossover/202606923393?epid=1205419923&hash=item2f2c504e81:g:8ucAAOSwIgNXrQG0 Etc, etc... |
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
From previous posts I guess you are a newbie to sound systems. In case you don't know the difference between active and passive it's as follows.
Passive crossovers act on the signal after it has left the amplifier. Passive crossovers for low bass are particularly hard to build. The components are very expensive and even then you will incur losses in power. Active crossovers act on the signal before it reaches the amplifier so no losses incurred. However you will need separate amplifiers for bass, mid and treble to go fully active. A good compromise would be to have passive crossovers in the mid/top cabinets and active for the bass. In this way you can use one side of the amplifier for bass, and the other side to feed your mid/top cabinets. Of course the system will be mono rather than stereo.
Visti
Thank you. I think i will buy something like that you recommended.
Visti
Thank you very much. Yes im new to this. So it helped a lot your message.
corell
Young Croc Joined: 19 August 2013 Location: Berlin Status: Offline Points: 1161 |
With all respect, do yourself a big favour and do quite some research before you buy anything.
Not only will you probably regret spending money on something which does not turn out as expected in the end but also the skills to properly run a system without failure (and costs to fix them) are very close to the skills of designing a system. Your questions indicate that you are new to the topic of builindg and running speakers. Give yourself some time and read some papers and books. You learn nothing over night. I built my first set of PA speakers after almost two years of extensive research including learning modelling and measuring software, meeting soundmen and asking questions on here. And still i would have done quite a lot differently from my perspective today. Edited by corell - 05 March 2019 at 3:31pm |
Visti
Thank you. Yes i will 100% read more about audio repleted things. I'ts just easy to ask here on the forum and i also fell like i learn a lot from you people. So i think a mix between those 2 things is good.
