Crossover |
Post Reply | Page <12 |
mini-mad
This IS part of his research. He's asking this large database (us!) For advise and guidance... so let's help him with links and walk-through as much as possible
Visti
Registered User Joined: 15 February 2019 Location: Denmark Status: Offline Points: 66 |
Exactly.
Visti
Would something like this (Behringer CX2310 V2) be good?
Earplug
Not the best, but out of stock anyway! This is better: https://www.thomannmusic.com/behringer_cx3400_super_x_pro_v2.htm |
Visti
I think that’s the one I will buy. Thanks.
JonB67
Before you buy that.
Describe the whole system. Tops? Subs? Amps? Music played? Where? Venue size? Audience size? For fun or for money? Budget? Its great that you're getting lots of bits of information but i think you might get a better big picture and much more focused help if you answer the questions ive posted above. For example you could use an fbq3102 which will do a basic active crossover and highpass for the subs if your tops have a built in crossover and give you an eq. They sell for peanuts on Ebay... like £15 to £20 if you keep an eye open. Or if you're going to do this a bit more seriously go straight in and get s second hand dcx2496 digital signal processor and you're ready to do all the processing you're likely to need until you jump up to the next level. It's hard to know which to advise when people havent got a top level idea what you're trying to do and with what kit. Hope that helps. |
Jo bg
Hi
maybe you stated it somewhere, but you could start by finding out what you are going to do with this before buying something... if you are really looking for 20 hz this crossover has a fixed subsonic filter at 25hz, you could use a variable one to experiment how low you need while retaining some protection. generally speaking analog crossovers like this are quite limited, with fixed frequency ranges, so you should really buy one that matches your needs. be prepared to study a bit or get someone you trust to advise you, or you are going to burn more money than needed - and it's not a cheap game anyway. |
Visti
To both of you. I will need it for a subwoofer(P AUDIO C18-650EL V2). I don't know what parts the others are now. My budget is a little small so i will take it slowly and buy the things when i have enough money.
partya
Registered User Joined: 06 September 2013 Location: New Zealand Status: Offline Points: 105 |
With regards to the Behringer CX2310, I would stay away from them (if they are available). I've had 2 relatively new units develop the same faults, rendering them useless. The CX3400 has proved more reliable.
Cheers
Turn it up! Turn what up?
Visti
Thanks for the warning. Then i will 100% go with the CX3400.
godathunder
Old Croc Joined: 19 July 2004 Location: wicklow Status: Offline Points: 1833 |
perhaps some good questions to ask before you go any further with purchases would be:
where am I going to use this equipment (small space/large space/outdoors - will there be noise restrictions, will there be health and safety restrictions) what size is the audience and what are they expecting (are they expecting a suicide party, a pro production or something inbetweeen - where inbetween) how much space do I have to store this and how can I transport it - do I have to set it up on my own or will I have help how much money can I afford to spend now and am I planning on spending more later (you will spend more regardless of your plans) what other systems have I heard and been impressed with - is something similar attainable - if not whats the best compromise I can afford if youre taking it seriously then this is not a cheap hobby and it may prove to be a stream of income but is more likely to be a labour of love. the initial investment for a decent system is quite steep my suggestions would be: buy a loudspeaker management system like the forementioned behringer dcx2496 it performs a lot of the tasks you will need (crossovers, limiters, eq, time allignment) in one unit and will probably work out cheaper than youll be able to find the individual units youll need to make your rig sound good its often a better idea to start by selecting the mid/high section and choosing a bass solution that will integrate well with that. you may want to consider building/buying something that plays full range which and can be used with or without a sub. later on you could add a more efficient dedicated mid/high and relegate the full range to monitor duties. most of all, work out what the job you want to do is and what tools you need to do it
Edited by godathunder - 05 March 2019 at 8:51pm |
LOUDER THAN LOUD
Visti
Thank you for the good advice. But i think i will stick with my plan, already bought some parts for the sub. I will look out to see if i find any dcx2496 or something like that.
