  New Posts New Posts RSS Feed - Crossovers
Crossovers
Jake R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake R Quote  Post ReplyReply Direct Link To This Post Topic: Crossovers
    Posted: 20 September 2011 at 7:59pm
HI
I'm looking to build some high power crossovers for some bass bins the woofers are FANE Sovereign 12-500LF each cab has a dual woofer so it's 2K max per bin and i can't find a decent low pass filter.
I was thinking of about 240Hz @ 36db cut off point. What components would be required or is there a crossover calculator??
Thanks
Jake
Thanks
Jake
Nitz V1505 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitz V1505 Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2011 at 8:09pm
I recommend using an active crossover so alot of power isnt wasted through heat in the passive crossover.
