  New Posts New Posts RSS Feed - Crown Amp ID?
Crown Amp ID?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Topic: Crown Amp ID?
    Posted: 24 December 2024 at 2:14pm
Hi.
Someone has offered a couple of these to me:--
The asking price isn't too bad - but no model numbers! I presume XLS602. Can anyone confirm - and if they are worth bothering with -- or just doorstops...
Cheers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 24 December 2024 at 2:45pm
I think that's a 402 rather than a 602, it's a c-audio GB402 in a different box.
Decent enough, british designed, mildly fiddly to service due to single board construction but they sold tons in the old and new form. Have a tendency to fill up with dust from my experience.
North Staffordshire
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 24 December 2024 at 3:10pm
Weight it. Easy way to tell what model it is then.
XLS-202: 21.0 lbs. (9.5 kg).
XLS-402: 25.3 lbs. (11.5 kg)
XLS-602: 27.2 lbs. (12.3 kg)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 24 December 2024 at 3:14pm
Aaah - ok, cheers.   Thumbs Up
I do like the fact that there are "proper" TO3's in there, NOT Class D - and no SMPS. Always a good sign.   LOL LOL LOL
The one I opened was a bit dusty, but not too bad. Under the main board was actually really clean. The dropper resistor for the fans was a bit brown, but that's normal. I was a bit curious about the lack of model number, though. I need to ask the owner what happened there. Chinese glue??   Evil Smile
Ok, cheers. Or the number of o/p devices...   Smile
Lucasdude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lucasdude Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2024 at 11:27am
I have an old C Audio GB602 that I use occasionally for a pair of 12"+1". Sounds great and has never set a foot wrong. It is a 3u chassis though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2024 at 12:24pm
Is that made in the UK -- or China?  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lucasdude Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2024 at 3:27pm
I would have to check but I'm pretty sure it's UK made. I've had enough fireworks displays to keep me away from Chinese kit unless that's what I'm aiming for...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2024 at 5:53pm
Yes, the old C-Audio amps were pretty solid. Really made before the rush to China. I do laugh at the often seen, "Designed In XYZ Country" then "Manufactured in China" seen on so much gear these days.
