Crown iTech series any good? |
Post Reply | Page 12> |
JamesFlipside
Registered User Joined: 14 July 2012 Location: London Status: Offline Points: 162 |
Posted: 10 September 2012 at 2:26pm |
What are people experiences with the crown iTech and MAi series?
"DFA switch fitted"
fredos666
Registered User Joined: 11 October 2008 Status: Offline Points: 205 |
Bad... Unreliable, blow for nothing... Specialy outside under the sun...
JamesFlipside
Thats a shame, considering the macro-tech series are such tanks.
Lab Gruppen FP+ ? |
"DFA switch fitted"
infrasound
Old Croc Joined: 13 May 2011 Location: Brizzle Status: Offline Points: 2276 |
FP+ =
JamesFlipside
So much money though :(
Are there second hand ones around? |
"DFA switch fitted"
Motion54
Old Croc Joined: 13 November 2010 Location: London Status: Offline Points: 1753 |
I've had two. Never has a problem. The earlier ones were unreliable when they 1st came out, but most if not all have gone back to crown and had faults rectified.
Used mine (Itech 8000), at carnival for 2days on sub duty at full pelt and no problems. In my opinion, one of the best sounding lightweight amps. Another dude on here (venture sounds) swears by them. I had 2 on ebay upto this weekend. Sold one but now decided to keep the other. Listen to people who have used them rather people who listen to rumours. I might know Someone who is selling one |
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4949 |
horrible things
North Staffordshire |
U.Viktor
Young Croc Joined: 04 May 2010 Status: Offline Points: 716 |
I-Techs are around the very few of good sounding switching amps. For example they are much better in mids-high range than Powersoft K series. The general problem with the I-techs is the reliability especially tons of boards and connectors inside. Two of mine even did not survive a single transport by van to remote area of Romania...
The roads in Romania are crazy bad anyways. Another thing is that I-tech has bit smaller power supply what you would except, so sometimes the long low-frequency tones are not so so strong. For example the PKN XD6000 beats the I-tech8000 in sustained power if we speak about low frequency response. Be very careful to get older/used ones! They had multiple glitches previously which has been eliminated then by hw/sw changes. Old ones are on the used market cause the repair is difficult and big rentals rather work with newer amps fully covered by warranty... Edited by U.Viktor - 11 September 2012 at 1:51pm |
lost eden
Young Croc Joined: 04 April 2011 Location: Dundee Status: Offline Points: 942 |
Was about to come running to the itech's defense, then realised what I've used are XTI...
U.Viktor
The XTI is a joke compared to an I-Tech ;-D
VentureSound
Young Croc Joined: 18 October 2009 Location: London N20 Status: Offline Points: 950 |
Really what Motion54 and U.Viktor said. I have three of these and they are good, powerful, nice sounding amps.
You need to be careful when buying used, as the very early ones were unreliable and nearly ruined Crown's name. Over the years of production Crown sorted out the problems, and there are about half a dozen mods which have been made, some electrical and some mechanical. Things like ribbon cables working loose/ going brittle (which were changed later for tougher ones etc), and a few small components were uprated. Internally they are very complex with lots of SMT components (similar to powersoft in complexity) and as such when they need repair need to be taken to the distributor or a Crown authorised repair centre rather than your local TV repair man.
U.Viktor
We have had to repair booth I-techs, PowersoftK and PKNs previously.
What was a surprise that Powersoft amps are really not so complex than
I-tech. The amplifier part of Crown is at least twice as more complex
than PowersoftK, probably this is the reason why the interleaved
switching of the Crown sounds far better than simple Class-D Powersoft
There are some parallel-connected small foil capacitors in the Crown , when one burns easily destroys the multilayer board and then pretty difficult to rescue the damaged board. |
