Crown K2 overlap adjustment problem |
Page <12 |
Randy Bohannon ![]() Registered User ![]() Joined: 29 May 2022 Location: London Status: Offline Points: 107 |
https://www.ebay.co.uk/itm/175455773476?hash=item28d9faa324:g:LbAAAOSw66ljVgt9&amdata=enc%3AAQAHAAAA4AOhbXPjYoD4RGMME0BAUFc6LPILBVLr%2FJ465acMCqxSY3ksZdotSJju3BuHlcnzRyMI4gfvOFcEsSPiz7USKbqCM%2BAp0zqh2bmImfeNOUtO8LoioF01RoqTU%2BhyCQj3Byp11%2BK6KNdCXkmxUktr1zPUgZXBBNRs2uaGEbK1sdtCY1QYjprcM2a7jBiMQ0Dqr6sDaQyUJ1cKcXtyIvd83rburxOdSNHfDFCGn%2BT%2FFQMkMoN1dujsxHUoapibenrbA0Vm29vqMQik9h2qeOZFTbz%2FWZBQawFssctc5m0K9VJD%7Ctkp%3ABFBMztHF_4ph
I found these as a possible replacement for the main caps, 125v and 10,000uF 35x70mm as compared to the originals' 110v and 8,200uF 35x80mm. The only issue is that JCCON isn't exactly the ne plus utra of capacitors though i did manage to find a datasheet: ![]() I mean, wtf is a "Horn capacitor" but at least it is the right voltage, size and capacitance; think I should take a punt and order a few to try? |
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4763 |
the crown caps have custom pins I think
North Staffordshire |
Bugger, I quite fancied replacing the main caps. There’s plenty of space for some sort of custom bracket for some better caps I suppose, back to the drawing board.
Page <12 |
