  New Posts New Posts RSS Feed - Crown K2 overlap adjustment problem
Randy Bohannon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy Bohannon Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2022 at 11:59am
https://www.ebay.co.uk/itm/175455773476?hash=item28d9faa324:g:LbAAAOSw66ljVgt9&amdata=enc%3AAQAHAAAA4AOhbXPjYoD4RGMME0BAUFc6LPILBVLr%2FJ465acMCqxSY3ksZdotSJju3BuHlcnzRyMI4gfvOFcEsSPiz7USKbqCM%2BAp0zqh2bmImfeNOUtO8LoioF01RoqTU%2BhyCQj3Byp11%2BK6KNdCXkmxUktr1zPUgZXBBNRs2uaGEbK1sdtCY1QYjprcM2a7jBiMQ0Dqr6sDaQyUJ1cKcXtyIvd83rburxOdSNHfDFCGn%2BT%2FFQMkMoN1dujsxHUoapibenrbA0Vm29vqMQik9h2qeOZFTbz%2FWZBQawFssctc5m0K9VJD%7Ctkp%3ABFBMztHF_4ph
I found these as a possible replacement for the main caps, 125v and 10,000uF 35x70mm as compared to the originals' 110v and 8,200uF 35x80mm.
The only issue is that JCCON isn't exactly the ne plus utra of capacitors though i did manage to find a datasheet:
I mean, wtf is a "Horn capacitor" but at least it is the right voltage, size and capacitance; think I should take a punt and order a few to try?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2022 at 12:43pm
the crown caps have custom pins I think
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy Bohannon Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2022 at 8:32pm
Bugger, I quite fancied replacing the main caps. There’s plenty of space for some sort of custom bracket for some better caps I suppose, back to the drawing board.
