Crown Micro-tech 1200 |
Post Reply | Page 12> |
mgftrophy
Registered User Joined: 20 November 2013 Location: Oporto Status: Offline Points: 103 |
Posted: 18 September 2014 at 1:02pm |
Hello guys , I have with me a Crown Micro-tech 1200 to test , a friend is trying to sell me for 100€/ 70£ , do you think is it worth nowadays buying a Crown Micro-tech 1200 in good shape to drive some 2 inch comp??
I will try drive 1x B&C DE85 8Ohms + 2x B&C DE45 16Ohms per channel with the micro-tech, it will do the job? Do you think the amp worth 70£ ? it is an amp with more than 20 years old, I know.. It will be better to buy something new? It´s gonna be my first Crown experience, I have many QSC MX/ JBL MPX MPA , CREST CA , CREST 8...PRO and 9001 series . Thanks Jorge |
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
sounds like a good deal, MT series are very similar to the MA series (Macrotech) so build quality is very high
North Staffordshire |
mgftrophy
Thanks K. Edwards
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
I would have thought one of those would fetch £100 - £150 in the UK although I guess the lack of front panel input controls will put off quite a few buyers.
mgftrophy
"the lack of front panel input controls" this is one reason that makes me think no to buy..
Dub Specialist Sound
Deffo i would snap it up straight away, i used to have one for many years, no problem with it at all, would of thought too its probley worth quite a bit more, used to have a crown micro-tech 1200 too sure i got about around 140£ for it
nothing wrong with the gains at the rear...imho grab it now!
mgftrophy
I did the test on the Crown mt1200 , and the result was:
first time I fired up, the ODEP light on channel 1 came on immediately, but on channel 2 the ODEP ligth went on after a minute or two! What problem is it? The amp was not used ten years.. always turned off.. and then I was try to get the sound from the two channels and It only came sound from Channel 1! the amp was in Stereo mode switch. Then I switch off the amp and tried the amp in paralel mono mode , the sound came from channel 1 ok, but the sound from channel two was completely distorted! The light from channel 2 ODEP started getting clearer now, but not completely brilliant as ODEP Channel 1. Then I thought, let give it a few minutes to warm up, and then I will try again. 30 min after , switch off the amp , and put it in stereo mode again, and tried again , now the sound was ok on the 2 channels , the ODEP light was full on the two channels, and the amp sound nice not distorted , but I still think the channel 2 didn´t sound as louder as channel 1 , but now was not distorted.. What do you sound guys , think about this Crown Micro-tech 1200? is their any problem with the amp? or is just dust and moisture? Best regards , Jorge.
DjLeco
Young Croc Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 817 |
Also sound is very neutral, clean and precise.
Edited by DjLeco - 18 September 2014 at 11:56pm |
Pinyorouk
Young Croc Joined: 31 January 2011 Status: Offline Points: 550 |
Used it on tops. Excellent!
Earplug
Open it up and give it a clean. Check the power supply condensors for leaking or bulging. They may need to be replaced on such an old amp.
mgftrophy
Thanks earplug, there are only 2 big condensors inside?
Do you think it is a good buy 100€ for this amp with this fault? Or do I make another offer 60 €/70€? Best regards Jorge. |
mgftrophy
How much is for one condensor? The fault is only on channel two.
But after 30min plugged on the amp makes good sound.. |
