  New Posts New Posts RSS Feed - Crown xti 4000 or inuke 6000
bcs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcs Quote  Post ReplyReply Direct Link To This Post Topic: Crown xti 4000 or inuke 6000
    Posted: 12 November 2017 at 1:54pm
Hi guys
Tired of carrying around the old tanks, I'm looking at lightweight amps to save my back. My 12 inch mid high cabs are loaded with beyma sm112n and cd10fe and tham15 loaded with beyma 15p1000fe. Just a pair of each. Which amp would be suitable between the crown and the behringer? I'm looking at getting one amp to run both tops and thams as the mid cabs have a passive c/o in them.
Many thanks
Mike
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2017 at 6:26pm
inuke 6000 has more power i have used mine for over 3 years it was powering a pair of 700 18" subs one side and pair of 12" midtops the other i know the 18's cud handle more ( i used heavy amps on them ) but it provided enuff spl for my needs i wud look at 2 inukes or inuke 12000 for more headroom Tongue
king david View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2017 at 7:18pm
get a lightweight 4 channel amp, so you can run all system with one amp, but stereo
APW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APW Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2017 at 7:54pm
that's fine until the psu in the amp dies, then its goodnight folks shows over.
On my small rig I use two lightweight amps, one for each stack ... if one dies it doesn't stop the show, we just carry on in mono.
Edited by APW - 17 November 2017 at 7:56pm
bcs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcs Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2017 at 7:59pm
Thanks guys
I decided two amps will be a better option. Any other amps in that price range I should look at as well.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2017 at 8:12pm
nothing comes close to inuke 6000dsp for price / weight /  features Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2017 at 8:16pm
Yeah, and finally go To sleep early
Edited by king david - 17 November 2017 at 8:16pm
