crown XTi's |
Post Reply | Page 123> |
VPAS
Registered User Joined: 05 December 2005 Status: Offline Points: 1203 |
Posted: 04 May 2007 at 5:50pm |
wots your opinions on these
http://www.crownaudio.com/amp_htm/xti.htm thinkin off getting some or something similar. i realsise this is a bit vague but i will give more info when i know what cabs im getting. just want some opinions on these really |
n^2 modulo -P = number wang
VPAS
bumpity bump......anyone?
Jay Lawless
Old Croc Joined: 22 August 2005 Location: United States Status: Offline Points: 1702 |
the XTi's are very nice, they don't suffer much from the same problems that the i-Techs do, but they are about the same aspect between the two, the XTi's seem more reliable and from what i hear, sound amazing. they are very nice amps .
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist |
Peter Moller
Old Croc Joined: 26 December 2005 Location: Denmark Status: Offline Points: 2531 |
Sound good, onboard DSP is cool, reasonably light, brand name product at an affordable price.. Reliability seems to be OK ( have installed a pair and used a pair for monitors w. no issues)
/peter
real phone no: +45 four zero six two four four nine eight ( using obvious anti phone spam encryption )
VPAS
i dont really understand this DSP thing.
can u set x-over freq's on the actual amp? |
Peter Moller
You can use the onboard DSP for limiting, EQ, delay, gain, crossover etc. Everything should be acessible from the front panel, but its much easier just connecting your laptop via USB and be able to dump the exact same presets into several amps quickly..
/peter
djstefanos
Old Croc Joined: 18 November 2005 Status: Offline Points: 2355 |
i own 3 of these things. never gave me trouble. saves you money on having to get an outboard dsp. these amps handle 2 ohms well but will get hot. 4ohms recommended. I suggest download the Architect software from Harman Pro before they remove it since they just got sold off. Download the program, install the amps and it is really nice to use.
johnno
Registered User Joined: 22 November 2006 Location: Australia Status: Offline Points: 162 |
I've been using a couple of the 2000's for foldback at a a venue for 10 weeks now.
The amps are driving 3 x 12"+1" jbl wedges and a 2x15"+2" drumfill.
One was unstable, it was replaced pretty quickly, my feeling it was the
drum fill (jbl) it was connected to.
The passive crossver failed a week after the amp was replaced.
The amps do get very warm running into 8 ohms, and hot when running
bridged into a 4 ohm load, the venue's ambient temperature could have
something to do with this, it gets really warm in there.
You might not like the distortion at 2 ohm loads, but at 4 and 8 ohm it's OK.
So far they've performed as per the specs, with the DSP they are pretty
good value for the $.
/John
djstefanos
some of the ribbon cables get loose inside. beware of that
VPAS
just bagged my first xti 4000 for £475 of ebay.....bargain :)
edit: as new, with original packageing Edited by VPAS - 08 May 2007 at 5:26pm |
Tony Wilkes
Yeah, me being a tight arse git only went up to £400 for it. Going to have to pay £690 for a new one now to go with the XTI 1000 i just bought. Write up your opinions when you have had chance to use it. Tony |
VPAS
will do. i wasnt the winning bider (second offer) but that may have just been some clever bidding on their behalf to get the bids up.
