  New Posts New Posts RSS Feed - cubo kick 12 cheaper driver
jumbo125 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jumbo125 Quote  Post ReplyReply Direct Link To This Post Topic: cubo kick 12 cheaper driver
    Posted: 19 February 2024 at 8:05am
Hi all SmileSmileSmile
I'm new here. SmileSmileSmile
As you can see my english is not perfectConfused, but I will do my best for good translation.LOL
I'm from Austria and in my past time I build some different Speakers (Tops and subs)
By searching for new 12"kick fill plans, I found the cubo Kick 12".
I'm very interested about this plan, but for me it's to expensive to build a double case with the suggest drivers.
Have anybody  an idea, what driver I can also use. The price should be not higher than 90-110$.
There is also an old Post with the same question.
The answer was this driver: Beyma 12WRS400.
For me it's very difficult to get this driver in Autria or Germany and it is also not so cheap.
I'm very glad, if there are some other drivers, that I can use.
Thanks a lot
Peter
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2024 at 10:31am
My bet would be something second hand. With that price range its almost impossible to find something comparble new. The 12WR400 is above budget for example.
APW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APW Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2024 at 10:42am
easy to get in Germany.... but more than you want to spend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jumbo125 Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2024 at 11:13am
https://www.bax-shop.de/beyma-12wrs400-400w-8-ohm-professional-12-inch-low-mid-bass-speaker - https://www.bax-shop.de/beyma-12wrs400-400w-8-ohm-professional-12-inch-low-mid-bass-speaker
yes of course, but the price is too high.
If there is another driver possible, I would be very glad.
Thanks for your answer. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2024 at 1:18pm
You could try this:-
A well made general purpose driver.  Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote jumbo125 Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2024 at 2:19pm
https://www.thomann.de/es/the__speaker_12_280_8_w.htm - https://www.thomann.de/es/the_box_speaker_12_280_8_w.htm
Yeah, this is great. Nice price.
So I will do this!
Does anybody know, is this driver also compatible with the MKH-230 case??
So I could build both cases, because I’m interested what case is better for me.
