  New Posts New Posts RSS Feed - cubo15 vs tham15, measured
Tonskulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2019 at 6:40pm
Even more comparsions. Real world listening tests still showing P540 as better choice for Tham15, compared to P200/A.   So now I tested P200/A 8ohm vs. P540, here are the results (Red=P200a):
At 40Hz, P540 is about 3dB louder and overall flatter bass response.
P200A has a lot bigger VAS (190 vs 100) and much lower FS (33 vs 56) while Qts, BL etc are pretty close.  Maybe this will help choosing the drivers for Tham 15.  It does like low vas high FS drivers according to this.
(I have actually noticed the same with HOG scoop. Low VAS medium FS the best and of course, strong motor).
Now let's test the same drivers in cubo 15...
Edited by Tonskulus - 30 October 2019 at 6:50pm
Jeferica View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeferica Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2020 at 8:38pm
hello. can you tell me if i can put paudio e15lf speakers in tham, or cubo, or any tapped horn? (15tlh30 for example)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2020 at 7:09pm
e15lf seems to be almost identical to RCF L15P540, according to specs.  Thus, I can say it works. Not the best driver for tham but it does give very tight/punchy and detailed bass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeferica Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2020 at 8:01pm
thanks a lot. i.m new into horn speakers and a total noob to make a graph in hornresp. i have 4 e15lf and 4 fane 15 400. all of them in reflex cabs. So i want to build some new cabs for them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeferica Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2020 at 6:27am
is that the original plan for tham? the one i found all over the internet? or you modify it? i.m gonna build one for test out of 18 chipboard (osb board)
and how about mk2? the one with 45' corners
Edited by Jeferica - 10 January 2020 at 7:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2020 at 9:26pm
Its the original version, there has been claims that it is the loudest one (most cabinet volume). Not sure about the sound quality differences with or without the reflectors.
