Custom Subwoofer For Robot! |
KTJames ![]() New Member ![]() ![]() Joined: 12 March 2023 Status: Offline Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 12 March 2023 at 10:00am |
Hi,
I am building a large robot with a built in PA! I'm exploring the possibility of building a custom enclosure for the sub woofers. The reason being; I only have a specific sized space in which to fit the sub woofers. I was wondering if anyone could give some advice as to existing designs that could either fit the space or be adapted to fit by tweaking the dimensions but keeping same volume and port size. The available space is also a slightly odd shape. I have about 500 to 600mm width to play with. I've had a little play in WINISD but to my mind it would make more sense to adapt an existing design rather than start from scratch? ![]() |
Currently trying to unfold a folded horn:
