cut off point for punishers |
Author | |||
myser
Registered User Joined: 24 March 2009 Status: Offline Points: 174 |
Posted: 15 September 2011 at 1:05pm |
how low could i expect to run a stack of 4 to 6 single punishers .. what could i cut them out at .. cheers ..
myser
infrasound
Old Croc Joined: 13 May 2011 Location: Brizzle Status: Offline Points: 2276 |
AFAIK, its 48hz for singles down to 42hz for stacks 4+
24db L/R slope I prefer to cut mine slightly lower though - as am rarely able to give them full throttle. A little boost at 40hz can be fun too.. |
myser
Sounds good
myser
Tocooltom
Young Croc Joined: 07 March 2011 Location: London Status: Offline Points: 1375 |
try 30 to 70 hz and the 24db LR slope and turn them up to 1kw each...feel the power!
infrasound
30??
Have you done this for any extended periods of time at power? |
cravings
yeah i wouldn't run them that low (not that i've ever even seen a punisher, just based on all people have said here)
Tocooltom
personaly i have done that with just 1 cab for a few hours at 1kw, not sure if that was the exact amount of power going into the drivers but it must have been close, the driver seemed to be fine, still played the same as it did when i turned it on till i turned it off.
Ive seen them used at 30 to 60hz and full power for longer than 6 hours and no problem at all. I think people might not like the sound of running puns down to 30 but it can be done, quote from walt regarding punisher response: http://forum.speakerplans.com/punisher-responce_topic2583.html
tomschute
Old Croc Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
and watch them fry. Ask someone who has experience running them, You might get away with 1k / 30Hz - but you can get with robbing banks if your lucky. I'd limit to 800watts and 40- 45Hz personally.Having repaired maybe 20 odd punishers in 3 years. One thing which someone might like to experiment with - many newer designed horns using super high excursion drivers set low high pass of 20Hz and the like with a shallow filter. The thinking being you have already reached xmax at 35Hz so why not take advantage of the cooling generated from lower frequencies. I'm not sure hwat the driver is doing below 40Hz, and with such a small chamber perhaps heat build up is too much of a problem... just a thought for someone with spare cash. Tom Edited by tomschute - 26 October 2011 at 2:21pm |
www.stableaudio.co.uk Speaker Building Services |
Tocooltom
Im just going off advice someone has given me, as well as testing it with one of my own for a few hours... but if you know otherwise then thats fair enough.
At the end of the day it comes down to experience and your right to say that, but when 2 peoples experiences have completely different outcomes....there could be a number of reasons why said driver did/didnt burn out etc etc... I dont want to argue over it but whos advice do you take when you are given 2 completely different points of view from 2 people who both know a lot more than i do? One says its going to burn out, the other says no? i dont want to burn my kit out but i want to get the most from it... EDIT: just spoke to my friend again just to make sure i wasnt talking total sh*t and i had the numbers slightly wrong, he runs them at 30 to 66hz on a 12db LR slope, hanging 4 puns from 5kw a channel. Best suited to drum and bass apparently. Anyway, experiment and find what is best for you. Edited by Tocooltom - 26 October 2011 at 5:35pm |
cravings
the quote above from walt says to high pass at 40hz... i would go with that advice. the other situation he describes is running it at very low power / volume in a domestic situation.. in this circumstance where you know the driver won't get battered you can relax with the high pass... but remember you're going to hammer yours..
tomschute
@ tocooltom
You are right it is tricky and with these things it all comes down to confidence and first hand experience ultimately. With all these things I always look at who i'm taking advice from, not so much the advice they give if you see what I mean. I know a couple of hire crews using Punishers week in week out. And they are busy running a successful business. I listen to them when they say don't put 1k into the bin. Tom |
