  New Posts New Posts RSS Feed - Cutting a double 18 horn... in half?
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Topic: Cutting a double 18 horn... in half?
    Posted: 29 July 2022 at 10:29am
i'm chatting to someone who has had some 218's made... and then cut them in half to make single horn loaded 18's
pretty sure they are F1 F218 copies.
is this a viable thing to do? it would of course "work" but i wonder if there was any acoustic coupling going on at the mouth of the horn where the two meet...
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2022 at 1:16pm
It would be fine. After all, F118’s exist.
smoore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smoore Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2022 at 9:13pm
It's very similar just half as loud ;) Put them together and same thing. Apart from maybe some different losses via the enclosure stiffness / vibrations
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2022 at 7:01pm
If you look on here you will find someone doing exactly that to a R E A L F215...
And you'll get to read the salty-tear'd comments about it too Wink
