CVR and Admark Amps |
Page <1 23456 8> |
Elliot Thompson ![]() Old Croc ![]() ![]() Joined: 02 April 2004 Location: United States Status: Offline Points: 5105 |
You may have forgotten that I don't use High Pass Filtering for Sub use. A HPF of 35 Hz 12 dB per octave is what I use for my low-mids. Familiarize yourself on the "Longevity Test" I made nearly 2 years ago. In addition to the "Tonal Characteristics Comparison" test. I recall before making that test, telling anyone who wanted a particular track tested on the K30 to let me know playing through my Double Eighteens (evaluated from 90 Hz - 17 Hz). No one from the Roots fraternity contacted me. Observing the Crest Factor test (100 Hz - 5 Hz), I literally ran a sine wave at each frequency listed to determine the output wattage. So, the amplifier is not the limiting factor. I would say, the boxes they are using and/or the loudspeakers not capable of playing very low frequencies with great efficiency is the limiting factor. Best Regards,
vibes92 ![]() Registered User ![]() Joined: 25 January 2020 Location: united kingdom Status: Offline Points: 59 |
lord ambassador (uk) uses an admark and found out he uses double 18s all along
luton_soundman ![]() Old Croc ![]() ![]() Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4506 |
Most of the amplifier conversations are always regarding POWER.... i wana know how an ampflifier SOUNDS, how refined is the sound? How well does it sustained the low lows below 40hz, whats the tone like? Having enough power is important but how it actually sounds is key for me personally
What amplifier (Brand) are you using at the moment that you want to compare the Admark/Morin to as a reference? Best Regards,
JBK ![]() Registered User ![]() Joined: 03 March 2016 Location: Besançon Status: Offline Points: 254 |
French soundman here, more and more reggae/dub sounds are going admark or rebadges, there are (at least) 2 resellers/rebadgers (hexa audio and mdm) in the counrty and they sell well. The advantage of getting a rebagdge at higher price is getting an amp correctly tested, having the 2 years full warranty, stocked spare piece in the same countrys, and easier/faster support after the 2 years. The drawback is ... well, the price. I know that they are very popular in other genres too (think free / rave party sounds) Seen a sound play 8 fane xb in larry scoops in a meeting in 2 ohms, sounded good and heavy, not eye-wobbling breath-taking heavy but I doubt you could with this box/speaker combo (huge room 1000 capacity). The soundman has done many gigs (1 year I think) and was very happy with the amp. I've heard many reports of the amp powering subs as it should and being reliable. A friend benched the same model, said that is hold its power in 8 and 4 ohms but in 2 ohms loose juice for the long sub notes (esp those hitting the lowest impedance point of the driver/box) due to the amp power supply not powerfull enough. So the output voltage drops. Fine in 4/8 ohms though. For the price one could have a spare one at the ready, able to be swapped for 4 ohms bass, or 2ohms mids / tops ...
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8079 |
Great Post. Confirmed much of what I was told/thinking. |
Hello, i do not wish to compare these with any amplifiers as they are of no interest to me
Below is a feedback from hornplan's forum user Mr One (translation by google with some corrections by me) This is the same model that I talked about in the above comment. One thing I didn't mention is some complaints that the amp's gain is stupidly high (45db) Also from my friend's bench test (not MrOne), the amp don't trip a 16A breaker on 8 or 4ohms full tilt. Remember here we have 16A 220V domestic power (even up to 230/240 in proper concert halls / big festival generators). Also IIRC the amp was delivering stated output in 2ohms on one channel only but voltage dropped rapidly if both were loaded. Don't quote me on that though. I am going to test it in 4ohms on sub (or maybe 2ohms on kicks or mids just to check but I don't intend to use the like that long term)
Edited by JBK - 20 March 2023 at 9:52am |
This tells me a lot. ![]() I have managed to pull 7.7A, on a 230V supply, when using 1x 8 ohm (nominal) driver, on 1x channel of Void Infinite 8 MK2, approx 7A, on a QSC RMX 5050. |
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3087 |
not sure pulling more peak current is necessarily a good thing!
which amp do we think the HA2600D is a rebadge of? Says it weighs 8.5kg which is very light. |
I don't subscribe to the magic "power drawn from an alternate universe theory", so I expect an amplifier to draw sufficient current, to output specified power. ![]() ![]() |
smitske96 ![]() Young Croc ![]() Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1035 |
Well, it is not magic if you understand the underlaying electronics. But everyone on the forum knows that the scoop section is not representable for the whole industry again. Just get an AD42 or comparable, and test it. Just jumping on conclusions based on various tests (and ignoring the positive ones) which all had different conditions, does not bring anyone anything.
Page <1 23456 8> |
