CVR D-3002 amp |
Post Reply | Page <12 |
Author | |||
They are used in a few West Indian Carnivals in the States, and haven't failed throughout an 8 hour to 10 hour period driving 21 inch woofers. The popularity is not very strong here for only a chosen few are willing to feed them the proper voltage (240 volts) to attain the best performance. Best Regards, |
levyte357-
I've seen test benchmarks, where Powersoft K10, with sine wave input ramps down output, after couple of seconds. From personal experience, I've seen K20 limit itself, with 8x subs and 40hz HPF. I've seen numerous other premier lightweight brands, such as older LaB FP series, on proper mains, clip before fully powering 8x cabs. I understand lightweight amps are not arc welders, not designed to be fed 40hz sine wave on bench, and achieve specs for at least 60 seconds. I also know lightweight amps are burst measured, to simulate real music. No misunderstanding or misinformation there. However as I said, no premier lightweight, truly achieves their spec, in a manner measurable on a bench. So what matters then, is buying amp that will power your subs sufficiently, not if your amp's specs are true, only at 1khz burst.
Timebomb
No lev, they meet there specification or there abouts. They never specified they would do a 40Hz sine wave for a minute, thats your specification, not theirs.
1 minute sine wave is a pointless test anyway as no music contains sine waves for anywhere near that duration. "However as I said, no premier lightweight, truly achieves their spec, in a manner measurable on a bench." You should really learn to understand what "truly achieves their spec" means before making statements like that. "there spec" means there spec, not your arbitrary test.
Edited by Timebomb - 24 February 2020 at 5:41pm |
levyte357-
In the interests of moving thread on, let's agree to disagree.
I've just bought 3x PL380, I know they won't provide same power as Void 8MK2, but I know they sound real warm 4 ohm stereo, and can draw up to 24A @ 240V doing it. My idea of a proper lightweight.
Zebby dubwise
Registered User Joined: 28 September 2018 Status: Offline Points: 39 |
Please forgive my ignorance generally. Feeding the proper voltage (240 volts) bemuses me. Are you suggesting that 110v 'out of the box' is inadequate? I have 2 x double 18" bass reflex's, each driver is rated @ 2,000 watts RMS so that's a total of 8,000 watts being 4,000 watts @ 4 ohms x 2. Thank you. |
It is not how much wattage the speakers are rated that is of importance as, how much amplifier wattage you have available to feed the loudspeakers.
Amplifiers that fall within the CVR D 3002, Powersoft K20 wattage range are aimed for 240-volts to achieve optimum performance. Once you cut the voltage by half, you are subjected to a 120-volt 30 ampere circuit. So, that would be 3600 watts long term being extracted from a 30 ampere circuit from a 120-volt line source.
If you are more concerned in what to expect from a burst wattage rating perspective, the peak rating (short term) of a 120-volt 30 ampere circuit before the breaker trips in terms of watts would be around 5100 watts (35.7 A).
The limiting factor will always be your line-source if you choose to power the CVR D 3002 amplifier on 120-volts.
Best Regards, Edited by Elliot Thompson - 27 February 2020 at 6:25am |
unclejam
Young Croc Joined: 14 January 2006 Location: United States Status: Offline Points: 525 |
So do these things sound good or nah? Compact amp racks with high power density are always highly appreciated.
