Dance Stack - Build Plan |
Post Reply | Page 12> |
rwnmc
Registered User Joined: 07 June 2017 Location: Ireland Status: Offline Points: 23 |
Posted: 05 October 2017 at 7:01pm |
Hi,
So I want to build I dance stack to play quite transient, kick driven electronic music. (Example: https://www.youtube.com/watch?v=_WQwoIWClUQ) My (current) plan is to build: 2 X1 Subs 4 HD 15's loaded with PD 184's for kick Something to meet the coaxial For mid-highs I want to use one of BMS's coaxial compression drivers with a casted horn. I'm wary about getting one for each side, this would surely be overkill? Also, would a 1.4" be worth the extra investment in my case or would the 2" do the same job just fine? Any thought/feedback or advice would be appreciated. I'd very much like to know if this is a solid choice of cabinets and drivers for what I intend to do. Extra info: This is a project, it's not for a large space or a certain size crowd. It's more about building a system thats plays this type of music with a quality and coherent sound that is both loud and clean. I am open to suggestions that completely blow my current plan out of the water. Thanks! edit*In review the plan has changed somewhat, and I wouldn't be surprised if it changes a couple of more times before it's solid Edited by rwnmc - 07 October 2017 at 10:29pm |
bassdesigner
Registered User Joined: 17 July 2016 Location: Lancashire Status: Offline Points: 228 |
No point running 1850's with hds swap the 1850 for x1's and stick with the hd's.
rwnmc
Thanks for the reply, could you elaborate on why the x1's would be a better choice?
bassdesigner
A pair of 1850 will only respond to around 50hz and will rapidly dropp off below that if your playing electronic music then the x1's will add that wobble that the 1850's wont pick up cross them over around 80hz and let the hds play from there you ideally want 4 hd to 2 x1s for a nice balance
Jo bg
It looks like you miss a fifth way, hd15 or cubo 15, or any bandpass horn, will never reach even the best bms coaxial, you need something to play at least 200 - 650 Hz... Or exchange the hd15 for something 90 - 600 capable
Jo bg
I am talking pa level, for hi fi use maybe you could cross the bms coaxial at 300 Hz
rwnmc
I was thinking there would be an issue with the coaxial hitting the low mid, thanks for confirming that one. Is there an option thats capable of 90-600?
If a fifth way is a best way to go I'm also up for introducing another cabinet.
Battered
Registered User Joined: 19 January 2013 Location: S.W. LONDON Status: Offline Points: 461 |
Short Version; 1850 isn't a Sub
Touching cloth at 200 mph
Mikkel
Young Croc Joined: 17 May 2013 Location: Huddersfield Status: Offline Points: 549 |
Maybe try simming some bph 12's? Ive seen some recently on rigresale that met a coax, think they were called rb212, might even be still selling. Anyway the soundsystem that were using them was called unstable or some in that vein.
Timebomb
Old Croc Joined: 11 October 2004 Location: Lancaster Status: Offline Points: 2717 |
RB212s are a FLH not a BPH.
Mikkel
Ahh well that explains why they go high enough to meet coax. To OP - i re read your post and i see its for a project, so im guessing buying might not be in keeping with what your wanting. So with that in mind there are designs that might be able meet a coax such as the martin 115 and martin 215 mk3, but i am only guessing. I think a 12" design would be better, but dont know of any (apart from the rb212 now hah). Maybe you could have a stab at designing your own with the help of the forum, if you know any horn theory and have used hornresp before? |
Mikkel
Or maybe the bass section of the xtro could work.
Found these as well, they are all 12". http://wizardaudio.hu/hasznos/hangfal%20tervek/bass/horn/12er%20Kickhorn.jpg http://wizardaudio.hu/hasznos/hangfal%20tervek/bass/horn/Fane%202x12%20Front%20loaded%20horn.jpg http://wizardaudio.hu/hasznos/hangfal%20tervek/bass/horn/MKB%20230.jpg http://wizardaudio.hu/hasznos/hangfal%20tervek/bass/horn/MKH%20230.jpg Hope it give you some ideas. |
