  New Posts New Posts RSS Feed - Database simulation
Database simulation
 Post Reply Post Reply Page  <1 212223
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 20 April 2016 at 2:15pm
I think all you got to do is to add cone & cutout volume to rearchamber, and remove reardriver volume from frontchamber. (cutout volume depends on from which side driver is mounted. Remember polarity might be reversed (or not if phase shifts at crossover freq)
Junior253 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Junior253 Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2016 at 8:55am
thank a lot for your response
mhtplsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhtplsh Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2017 at 3:37am
Originally posted by bitzo bitzo wrote:
Mt121 without any horn for 2" compression driver
s1=360.8
s2=872.2
con=25.3
s3=1944
con=21
vrc=17.6
lrc=14.8
fr=0
tal=0
atc=1108
vtc=615.75
I am not able to understand how atc 1108 is calculated here.
Herewith posting picture with detailed drawing. of MT 121.
Daniel Twellmann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Twellmann Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2017 at 8:45am
14cm*14cm*pi*1.8cm = 1108cm^3
Contour View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Contour Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2017 at 9:24am
Atc should be an area not a volume?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Twellmann Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2017 at 2:17pm
Yes, I just showed how 1108 was calculated :)
ATC and vtc should be switched around
Edited by Daniel Twellmann - 08 July 2017 at 2:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhtplsh Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2017 at 2:01pm
From where you use 1.8 in the calculations. The plywood here is 12mm thick.
Please let me know what do you mean by ATC and vtc should be switched.
