Davey T's 215 bootybass - WITH PLANS |
Page <12345 15> |
minaximal
Joined: 26 September 2004 Location: United Kingdom Status: Offline Points: 1784 |
Posted: 11 June 2009 at 11:44am |
nice one davey!, think you should keep the bootybass name! @pfly your cab is in 4pi not 2pi the driver sensitvity was probably done in 2pi, did you also do the combined response for the spl sim? p.s. if the cab is designed to always be stacked off the ground then a 4pi sim may be closer to the truth, it is pretty much the case for the shorter wavelengths of upper bass mid. |
pfly
Joined: 25 October 2007 Location: Helsinki, Fin Status: Offline Points: 2827 |
Posted: 11 June 2009 at 12:01pm |
That is the reason why I did in 4pi, in 2pi it gets somewhere around the nominal sensitivity of PD12SB30. Then if there was double version of this it would get to around 100db...
Well, back to bootybass I guess. Nice design btw! Edited by pfly - 11 June 2009 at 12:02pm |
darkmatter
Joined: 26 February 2005 Location: LDN Status: Offline Points: 2419 |
Posted: 11 June 2009 at 1:31pm |
nice!
yep ![]() or phase plugged beyma 122nd and neo 1.4" could be good. |
davey t
Joined: 11 March 2004 Location: Bristol UK Status: Offline Points: 1428 |
Posted: 11 June 2009 at 7:24pm |
Yea if its on the ground then 2pi- thats almost 5db difference! The drivers are around 99db reflex loaded. The horn expension on the port adds around 3 db compared with the normal reflex and doubling the cab with two 15"s and still keeping 1w increased it further by 2 or 3db.
I have to say that I came across your thread a few weeks back which kinda inspired the loading here. That and there's a similar RCF cab i believe and a whole host of other varieties. :)
turbodeas
Joined: 06 August 2005 Location: United Kingdom Status: Offline Points: 293 |
Posted: 11 June 2009 at 9:54pm |
Hey,
Really nice Davey, looks like it'd be ideal (and nice and cheap) as the low end for the little (but a bit bigger) pub gigs where the pair of SRM450's on sticks isn't quite enough! What do you reckon the max SPL using the Sov400's would be like? Good enough for smallish PA use? I'm sorely tempted to build a pair as soon as I get paid, jsut for fun! The sensitivity sure looks impressive.... Love to see some pics of your build when you've finished it. Cheers, Chris. |
king david
Joined: 17 January 2007 Location: italy Status: Offline Points: 1329 |
Posted: 11 June 2009 at 10:16pm |
i cut the wood today for a single driver version, i guess i will build it in a day but i will work hard in the next days so no woodwork for me, i think to do it early next week and test it both indoors and outdoors.
it would stack well above hogs and below smt212 so i hope it would work good
king david
Posted: 12 June 2009 at 12:44pm |
actually i found time to start the build today, i think that the 39,7cm baffle is wrong and needs to be 41 or 41,1 cm so back to cutter.
davey t
Posted: 13 June 2009 at 11:38am |
Let race....
currently half way there with just one afternoons work. I can't believe how easy this cab is to make. I mean, there's no messing around with routing access panels or anything like that. Only 6 angled cuts, all the others are 90degrees. and its small too! when you draw things on a computer you don't really get a sense of scale. Looking forward to finishing and testing ![]() Edited by davey t - 13 June 2009 at 11:43am |
rich_gale
Joined: 18 February 2008 Status: Offline Points: 2697 |
Posted: 13 June 2009 at 10:23pm |
looking good champ..
how you imagine this performing when scaled down to fit a pair of 12" drivers? im thinking making them in two halfs aswell..
also, as a horn assisted reflex cab, what ts para's should be aimed for when chosing a driver? will a lower resonance driver allow a lower cutoff as with reflex(at a cost to efficiency because lower fs normally means lower w/spl's), or does the driver want specs suited best for a scoop cabinet? I have a pair of 12" dual vc woofers and wanna make use of them in something different to my usual box with a hole aproach..
shadow1
Joined: 05 March 2008 Location: West Midlands Status: Offline Points: 308 |
Posted: 13 June 2009 at 10:39pm |
It's looking good man, looking forward to the final result.
Smile, the worst is yet to come.
palesha
Joined: 08 April 2006 Location: India Status: Offline Points: 53 |
Posted: 17 June 2009 at 7:41am |
From where u got Le of the driver? The Fane website is down. In the web catalogue Le is not mentioned. |
davey t
Posted: 17 June 2009 at 9:07am |
I guessed. It only effects upper response anyways
Page <12345 15> |
