  New Posts New Posts RSS Feed - dB Mark DP48+ sound quality
RooKa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RooKa Quote  Post ReplyReply Direct Link To This Post Topic: dB Mark DP48+ sound quality
    Posted: 30 May 2023 at 6:09pm
Hi guys I was wondering if anyone's used the dB Mark DP48+
How is it sound quality wise etc compared to a Behringer DCX2492? My DCX gave up the ghost too which I shouldn't be surprised Confused unfortunately there's not much on the dB,s as the market seems to be in Vietnam etc
Cheers!
Edited by RooKa - 30 May 2023 at 6:09pm
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2023 at 6:20pm
I noticed a huge change in idle noise switching from dcx to dB Mark in the studio , so for starters lower noise floor which could translate into a more transparent sound .
Post Options Post Options   Thanks (0) Thanks(0)   Quote RooKa Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2023 at 6:35pm
Ahhh thankyou man is there any negatives would you say? I found the Behringer lacked any real depth ialmost as if there was a blanket over the sound if that makes sense.. so I'm hoping for a bigger improvement in that area
Edited by RooKa - 30 May 2023 at 6:38pm
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2023 at 6:52pm
Can't say anything that drastic , but the dbmark is definitely a step up from the dcx . Less noise was enough for me to be satisfied and it definitely doesn't blanket the sound .
Post Options Post Options   Thanks (0) Thanks(0)   Quote RooKa Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2023 at 6:57pm
Ahhh good to hear, just a quick one whats the purpose if having 4 inputs into the crossover oppose to the 2 on say the DP28+
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2023 at 8:08pm
Well obviously you can connect more sources , can't remember I ever needed 4 inputs but for some specific needs or jobs it makes sense .
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2023 at 10:53pm
Means you can run four biamped mixes off one processor eg for multiple monitor mixes etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RooKa Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2023 at 11:00am
Ahh okay gotcha not something I'd need forever the time being.. cheers man
