DB mark DP48II software/control software |
Post Reply | Page 12> |
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1502 |
Posted: 05 December 2018 at 3:04pm |
I have a DB mark DP48II.
Is there any software up available for it? if so how is it done? Its currently on v4.3.2. I also have a DB mark DP36II which is on A-DV1.02. My Mac (laptop) died from logic board failure, I was using a Mac with parallels desktop (running windows XP I think) which has worked fine for years. New laptop with parallels desktop and windows 10 the DP48 is not showing up on the control software but the DP36 is. Would anyone know how, why or what to the above? thanks |
In the Truth there is no news, and in the News there is no truth
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
you need to use the software number that matches your product firmware number.
have you down loaded the drivers for your dp48.
dlyxover
Hi bee
I thought I had but it appears not. Could you point me to the correct ones? In windows the 'prolific usb to serial port' has a error on on DP48 but not the DP36 " This device cannot start. (Code 10) A device which does not exist was specified. " Edited by dlyxover - 05 December 2018 at 8:53pm |
bee
whats the firmware code on the device.
dlyxover
Where do I find that?
bee
on the unit, go through menu options. device settings..
dlyxover
on the system set up menu
option 6 (system information) its says "speaker processor V4.3.2" can't find anything else. |
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2582 |
I Have an old Driver DVD in my database. It should work with your version. It's uploading to wetransfer as we speak
Mircea Bartic
dlyxover
Mircea I've installed the driver from your download and the software but still no joy.
I'm beginning to think its a windows 10 software issue or the USB to serial board on the DP48 has failed. In windows device manager, its still got the yellow ! triangle and "This device cannot start. (Code 10) A device which does not exist was specified." in device status. But with the DP36 (which is working) it dose not have warning in device manager.
kedwardsleisure
I've had a similar problem, tried it on an XP computer and worked first time, was the same firmware version as yours too.
North Staffordshire |
Guests
Guest |
Perhaps they used a fake prolific serial chip:
