  New Posts New Posts RSS Feed - Digi Pro Amp module Fixed!!!
nuclearbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Topic: Digi Pro Amp module Fixed!!!
    Posted: 30 November 2017 at 12:44pm
Hi guys I’m trying to source a service manual for the amp module for the dB tech 18D box
Edited by nuclearbass - 01 March 2018 at 1:28pm
one life - have fun!
Force fusion pro audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2017 at 1:42am
Still on the look out for this, I’m hoping not to have to send it back to db for repair and get shafted 🙈
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2017 at 8:49am
good luck, nobody has the infos on these digipro modules
dylan-penguinmedia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dylan-penguinmedia Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2017 at 9:00am
Try Ampman...
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2017 at 11:23am
I’ve dropped him an email cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2018 at 9:07pm
Andy amp says he can’t help, any other suggestions
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2018 at 6:57pm
Originally posted by efinque efinque wrote:
I too have a defunct sub15... I think the problem is with the driver. Try dB Tech directly?
I've found some OEM amp modules but they don't provide enough power (50W max)
DBS charges are pretty steep
But looks like I’m going to have to suck it up
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2018 at 11:22pm
RCF also use the digimod amps. ISTR the last one didn't leave much change from £400.
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2018 at 6:39am
Not what I wanted to hear 😂
It’s frustraiting now as I’ve had it to 2 good amp guys that can’t find any issues with it and cant work out why it’s stuck in mute mode.
It powers up fine but won’t come out of mute, looks like it’s going to one of DBs authorised guys then, I have a feeling I’m gunna need my vasciline
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2018 at 6:42am
Also am I right in thinking those digimod modules are powersoft?
There’s nothing on the module no model or branding ?
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2018 at 9:01am
From what i've heard, those digimod modules are definitely not powersoft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2018 at 9:05am
Who’s made them mate do you know?
Just googled digimod
And come across these
http://www.powersoft-audio.com/en/oem-solutions/digimod#DigiMod%203004PFC2
Was also told there the same as what Sherman are using in their powered stuff and I believe there using powersoft too
