DBX 260........... |
Author | ||||||||||||||||||||||||||||||||||||
sukebe
Registered User Joined: 07 June 2007 Status: Offline Points: 132 |
Posted: 18 September 2007 at 5:26pm |
Anyone got one or used one?
Am about to buy one and just seeing what peoples veiws were on them. They're about £700 over here, or about half that in the states (plus p+p and possible duty to be paid) Any views are welcome |
Dom
Old Croc Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
Had one. I think Toastygoast has it now.
Good crossover. Not to be confused with the DRPA which is pretty rubbish.
Bang for buck you get a lot, with GEQ, Compressor, Feedback Suppressor, Auto Gain, Gates, Subharmonic synth if that's your bag, etc plus the normal delay, xover, PEQ and limiters... Routing is good - can't think of any xover config you can't do with it. Plenty of processing power and the GUI is good.
Drawbacks are you can't network them like the 480, only two inputs (3 inputs is quite good for Stereo Mids and Tops, Mono bass and mono monitor run off a booth output).
Unlike the 480 which has a universal power supply the 260 is made in 110 and 220v versions. If you're importing them from the US then you'll need to either get hold of an export (220v) model or find a way of running them on 110v.
You'll need to factor in about 22% to cover VAT and import duty on top of the purchase price including shipping costs. You might get away with less, but you should be prepared for the worst. Use a reputable shipping company such as Fed Ex or DHL or you can easily end up getting stung with loads of hidden costs for customs clearance etc.
toastyghost
Yep, and pretty happy with it. We have the use of two, the older one's still got a small wiring fault where the screen goes garbled but a reset fixes that and it's fine once you've got it started. The limiters are pretty flexible, once you get your head around the naming convention they use and the EQ is pretty nice too. Often use the AGC (automatic gain control) to ensure that the rig is run at a nice level all night. |
SteveAATW
Young Croc Joined: 04 September 2007 Status: Offline Points: 1173 |
£500~ will get you a used BSS Minidrive, £875~ will get you a second hand DP226, I'd take either of them over a 260 to be honest
sukebe
so does this mean that i have to run the mids and tops in mono? |
Dom
No. It means you can't run a monitor from a 3rd input...
sukebe
well, i got a small 12" + 1" wharfdale PA, i was going to use. It has its own mixer amp, and i was going to plug that into the record out of the mixer. Will this be ok, or will there be delays/other issues arrising from that?
Jack The Nutt
Registered User Joined: 15 January 2006 Location: West midlands Status: Offline Points: 217 |
Not sure about delay but don't think so. Main prob is no control over signal level as record out is set and not adjustable, use an aux send if it has one.
ad-d
Registered User Joined: 06 November 2005 Location: United Kingdom Status: Offline Points: 507 |
To be honest from the specs of those 3 you'd be better off buying the Sony SRP-F300 I'm selling, cheaper than those 3 as well. It's a high quality yet little known LMS but cost a lot more than any of them new and even now still has a superior spec and performance...
At only £479.95 it's well worth serious consideration...
Edited by ad-d - 24 September 2007 at 1:55am |
H..
Registered User Joined: 07 August 2007 Location: Thailand Status: Offline Points: 197 |
But what sounds the best out of the 4 options ???
djrockstar4u
Registered User Joined: 15 October 2007 Location: United States Status: Offline Points: 82 |
Personally I really like my Drive rack PA, it's good for touring, does what you need it to do, and it's reliable. You can count on it to last through your shows, unlike Behringer, it really is hit and miss with their stuff. But i've never had any trouble with the PA and you still get quite a bit of features.
norty303
Again, don't brand all Behringer products the same, they have some good units in amongst the unreliable products. There are lots of people running DCX's on some good rigs with no problems, and as some have said, would rather use the DCX over a DRPA.
