Dead BBS Opal FCS 966 eq? |
Wivman
Joined: 02 September 2010 Location: Essex Status: Offline Points: 97 |
Topic: Dead BBS Opal FCS 966 eq?Posted: 17 January 2011 at 8:32pm |
Evening, Gents
Just tried to test my system, but found that my eq appears to be stuck in by-pass regardless of whether the by-pass buttons or press in or out. The lights are lit to say that the signal is going through and signal is appearing at the LMS, but there is no signal registering on the eq's meters and none of the faders or controls have any effect. Any ideas on what the problem is and how to fix it? The manual says it uses relays to allow the signal through with the unit on by-pass or turned off. Could it/they be faulty or stuck. All thoughts very welcome. Cheers Ian
PISSHEAD
Joined: 24 July 2004 Location: West Midlands Status: Offline Points: 586 |
Posted: 17 January 2011 at 8:41pm |
The 'drunken master' strikes again.
Wivman
Posted: 17 January 2011 at 8:49pm |
Thanks for the link to the repair man
![]() Just wondered if anyone else had heard of this problem before I send it off to the doctors? |
service dept Steve
Joined: 30 January 2010 Location: S.W.London Status: Offline Points: 2050 |
Posted: 17 January 2011 at 10:42pm |
If you feel competent and with the unit disconnected from the mains pop the top off and check the two fuses on the circuit board inside. You may get a certain amount of lights with one fuse gone but the relays will not power up without both intact. They are quite a low value, 500ma I think, 20mm glass ones, and sometimes go just to be spiteful. (and sometimes not so check them again if it still won't go, them off t the menders)
Edited by service dept Steve - 17 January 2011 at 10:42pm |
We are not "They", We are "The others"http://www.servicedept.co.uk -
shagnasty
Joined: 30 July 2007 Location: Guildford, UK Status: Offline Points: 7683 |
Posted: 17 January 2011 at 11:37pm |
Having spent some time in a pile of 966s recently the top comes off and you get to the main board really easily but to go further than that you have strip the thing to bits which is a bit involved.
Check the fuses and check the PSU rails, the toroidal has 3 wire to the PCB for LV so find the 0V and check you have rail above and below that, also worth checking if the relays click with the bypass buttons...
Wivman
Posted: 18 January 2011 at 6:44am |
Thanks, guys. I'll check the fuses.
JJ Kaos
Posted: 28 March 2024 at 1:22am |
I know this is a very old post but I’ve got exactly the same thing going on. Did you get yours sorted in the end? Was it just a fuse? Cheers
