Decisions decisions... |
Post Reply | Page <12 |
Earplug
Thanks(1)
Go to the Yamaha product page and look at the bit that says "FIR-X tuning". That may be why the bin doesn´t like your other cabs. Here: http://www.yamahaproaudio.com/global/en/products/speakers/dsr_series/features.jsp#1411674 EDIT: " It just seems odd that the passive crossover in the cabinet" Definitely not a passive! Edited by Earplug - 15 September 2017 at 7:11pm |
Guthix
Registered User Joined: 09 November 2015 Status: Offline Points: 69 |
Ahh right I see what you mean now, the sub is essentially tuned to integrate well with cabinets in the same model range. Correct? My bad, digital crossover not passive. I meant internal I suppose.
Crashpc
Registered User Joined: 26 February 2008 Location: Czech Republic Status: Offline Points: 465 |
Ah, passive crossover in a way of bass box, it can also be a problem. You should try more powerful amp and some DSP to find out. Keep in mind that to a point, higher reproduced frequencies actually sound tighter, and even tighter when you cut bottom under 45Hz.
The tops alignment mentioned by the other poster is meant that tops and subwoofer don't overshadow each other and these are in phase at crossover frequency. Otherwise you can get into weird bass anomalies. Before changing tops you might even consider upgrading your signal path, processing and or amps. Generally everything, so to speak. :-D // bhaha, confusion. You're all too fast! :-D Edited by Crashpc - 15 September 2017 at 7:27pm |
Guthix
The subwoofer is active so I can't try a more powerful amp ;) But yes an active crossover and a graphic eq would be a good upgrade, I guess that would prevent "weird bass anomalies"? By that you mean phasing issues I think?
haha thanks for the advice :)
Guthix
Also guys, would it be best just to buy an LMS? Rather than getting a separate EQ, crossover, limiter etc.
toastyghost
You'd be better off just buying the matching tops for your active sub as has been recommended numerous times already…
Guthix
Yes that has been my intention for some time now. I'm talking about upgrading my signal processing as well, not instead.
