  New Posts New Posts RSS Feed - delays with scoops
delays with scoops
sonofalesbian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sonofalesbian Quote  Post ReplyReply Direct Link To This Post Topic: delays with scoops
    Posted: 03 July 2010 at 10:36am
i am getting round to setting the delays on a system i'm putting together for a night, it consists of four scoops, 2 horn loaded kick/bass bins and some tops.
A) Whats the best way for working out the delay times?
B) Is there anything in particular i need to do with my scoops or shall i treat them as direct radiators?
cheers
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2010 at 11:16am
Somehow, don't think you'll get much response here...
I asked this while ago, many differing opinions...
"What works for me" is, delay each cab above the scoop, by the difference in horn length to the scoop.
For compression drivers, calculate using length of the horn.
DCX 2496, allow delays to specified in cm, which is very useful. If you don't know specific horn length of your scoop, and its 18" (and not HOG), it's prob about 190cm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sonofalesbian Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2010 at 12:02pm
cheers levyte, thats all i need to know!
AlfieDring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfieDring Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2010 at 1:00pm
I agree with lev on the delay but ALSO run scoops with phase inverted! To get your head round that imagine it was a normal horn without the direct radiation, you'd delay it by the path length but the driver would (normally) be facing into the throat. Scoops are the other way around so either flip the phase on the LMS or wire the box with reversed polarity.
Alf
phildat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phildat Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2010 at 1:07pm
down to personal preference that one. last night was running rhinos reversed polarity for a hard tek/gabba night (Confused a hire) but i prefer not to reverse polarity when playing roots an dub. I think the slight delay scoops give when not reversed makes reggae feel better. Think someone on here described it as lazy bass!   imho, mind!
Its just a ride.
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2010 at 1:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2010 at 7:47pm
Glad to pass on answers I got from here..
Smithers I believe, provided that answer...
smithers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smithers Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2010 at 5:20pm
Glad to pass on answers I got from here..Smithers I believe, provided that answer...
i think it was more of a collective conclusion Lev!
