delays |
Future-House
Registered User Joined: 30 January 2015 Status: Offline Points: 83 |
Posted: 05 December 2017 at 6:28pm |
18in Wbin
Hd15 x 2 4 tops will i get a problem with delays? |
mini-mad
Little bit... the kicks and w-bin are horn loaded.
I do believe unless it's a particularly long path or ported the w-bin it won't go low-low. Edited by mini-mad - 05 December 2017 at 7:08pm |
Future-House
can i make it ported by adding 2 or 3 holes?
here is a photo
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1292 |
Nice shed
Future-House
woke up many times in it
Edited by Future-House - 05 December 2017 at 9:15pm |
mini-mad
That's no shed... that's a Wendy house!! (Or in my daughter's case a zombie fortress) |
Future-House
indeed a zombie fortress, full of nerf guns ;)
Future-House
this port
mini-mad
Like that yes... but don't go just cutting into the bin you have. At least IF you are going to butcher the one you have at least measure the volume of the box the driver sits in and tune it to about 45-50hz. It WILL have a slight attenuating effect on the horn loading but you're trading extension for SPL. So plan carefully before cutting into your boxes. |
JonB67
Think if i was going to do that id cut holes and put tubes in rather than a slot. At least you can pull the ports easily to adjust length then if the tuning isn't right.
