Delta 15LF vs. Kappa 15LF vs. PD154 |
Post Reply | Page <12 |
Timebomb
Ive got 8 kappa 15lf hds and im very happy with them, pds sounded
a bit tighter and go a tad louder when i heard them but not a lot more,
the kappas are fine in hds. Think they will go a little lower
than the pds too.
dj-holocaust
Registered User Joined: 24 May 2007 Status: Offline Points: 140 |
Thanks for advice chaps
dj-holocaust
What frequency range do you run through your kappa's to get the best sound?
Timebomb
About 50hz-140/160hz, depends on what tops were using but the the hds
are fine upto 160. we have run them with bandpass subs from
80Hz up wich sounds a bit smoother and gos lower. a 50Hz hpf or
higher is a good idea, can mabie go a bit lower in large stacks.
dj-holocaust
Thanks mate much appreciated.
I,ll be running vega psx153's as mids so i'll cut them off below 140/160hz.
hudson
Registered User Joined: 17 May 2007 Status: Offline Points: 23 |
"but was there not someone on here recently talkin out havin p audios
rippin themselves apart on hd15's maybe not that particualr model i
dunno"
ye, that was a problem with the challenger series i think. maybe somehting like the SD 15 would be better suited.... maybe have alook at some of the neo p audio divers, they start off around 80 quid, no idea what they'll sound like though. Edited by hudson - 28 June 2007 at 9:58am |
dj-holocaust
iVE ORDERED SOME EMINENCE SO HOPEFULLY THEY'LL DO THE JOB FOR NOW.
Will post feedback when I get them in action
guitarplayerjoe
Registered User Joined: 31 August 2011 Location: Manchester Status: Offline Points: 194 |
Did you ever post feedback on your drivers? I'm interested in building two scoops with either kappa 15lf or delta pro 15a i was wondering how yours sounded?
Although five years later I'll be lucky if i get a reply. Cheers.
