  New Posts New Posts RSS Feed - Denon DNS3500 screen fault
hmaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 24 December 2013 at 9:46pm
Abit off topic i know we had a problem with our's where we would get a massive belt when touched the platter or enything metal.
They come with a plug converter thing and use the neutral as a earth so make sure its the right way or replace with a proper plug, or enything thats earthed is now live.
ultrascan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrascan Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2015 at 12:36am
Hi all
No display is usually caused by ZD903, it is a surface mount diode on the underside of the power supply board, a tiny little thing, this is a 2.4 volt zener diode, care is required when removing it, but you can fit a real 2.4 volt zener diode on the underside of the board, the cathode is to the right with the diode position closest to you,  I used a 2.6 volt as that is what  I had to hand working no problems.good luck and don't forget to disconnect the unit from the mains supply before working on it, or you will have problems also make a note of the direction of the ribbon cables checking on what side the blue bit is before disconnecting them, it will save you a lot of time and trouble. good luck, kr Pete
Edited by ultrascan - 06 December 2015 at 12:38am
Nomakon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nomakon Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2019 at 7:13pm
FIXED I PUT A DIODE Zenner 1n5221 1/4w non SMD adapt the DIODE. Works correctly.
This page was generated in 0.110 seconds.
