  New Posts New Posts RSS Feed - Denon DNS3500 screen fault
Majestic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Topic: Denon DNS3500 screen fault
    Posted: 01 October 2013 at 1:36pm
Hi guys,
This puppy has a screen fault, nothing appears. I replaced the screen and the problem still remains. Any ideas?
Thanks
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2013 at 9:22pm
PSU fault?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2013 at 11:34pm
You'll have to elaborate greatly to get a meaningful answer from a distance.
What checks have you made that lead you to think the screen was faulty? Was it smashed? Does the rest of the machine work ok? The info on a VFD goes through a tortuous path before it makes the pixels light up.
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2013 at 12:41am
May be a PSU fault.
I tried changing boards from a spare, but not even switching on now.
Do you know which components could have failed?
Thanks
Edited by Majestic - 02 October 2013 at 12:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2013 at 12:55am
Thanks for the reply.
No physical damage to the display, the denon logo flashed when was switched on. Everything else WAS functioning normal before I messed about.
I followed up on Eddies suggestion and changed the PSU from a spare 120v version, maybe that was a bad idea though as now it doesnt switch on at all. When i changed back to the original PSU, the denon logo had a pale flash but now there is no sign of life. All the fuses are ok and ribbon cables have been attached. What have I done?!
Edited by Majestic - 02 October 2013 at 8:06am
Masai View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Masai Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2013 at 11:59am
It does amaze me when I read on here how people go under the hood of a high voltage amplifier or a sophisticated bit of electronic kit which cost hundreds of pounds to have a poke around with no previous knowledge or experience of repairing such pieces of equipment and expect to some how fix it Confused Shocked
You could have saved yourself a lot of bother (and now money) by just giving it out to a Denon authorised service who would have not only sorted out the problem but also give it service and software upgrade if needed. I'm not sure how old your unit is but is it still under warranty? Silly question maybe but I thought it best to ask...
I think you've learned a valuable lesson from your tinkering but I hope you get the unit sorted out. Good luck! Handshake
Facebook: Masai Judah
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2013 at 12:58pm
Lesson learnt. Its not high voltage though, i wouldnt be sticking my screwdriver into an amplifier without discharging the capacitors first
Looks like i will be trying to get someone qualified to fix this one now. As it stands i now have 2 dead units and one fully working one to compare tests. Are there any links to free service manuals for these, all the one i can find are pay to download.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2013 at 8:52pm
PM sent
re high voltage - denon dns3500 uses a switchmode PSU at a very lethal 340VDC
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Masai Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2013 at 9:45am
So it's a case of 2 down and 1 to go yet you want a service manual??Confused
Doesn't sound like you've learnt your lesson to me..... Oh well......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2013 at 1:49pm
Thanks for your help and the warning Kev.
I will be getting someone else to fix it for me
oscillo1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oscillo1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2013 at 7:32pm
Hi guys,
Do you find solution for you problem?
Solution, replace ZD903 on power unit.
ZD903     00D 276 0831 902       0ZDZ2.4-Z
Regards
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Posted: 22 December 2013 at 10:06pm
Originally posted by oscillo1 oscillo1 wrote:
Hi guys,
Regards
Thanks for your help. Do you know where to order the parts?
