Denon DNS3500 screen fault |
Post Reply | Page <12 |
hmaudio
Old Croc Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 3844 |
Abit off topic i know we had a problem with our's where we would get a massive belt when touched the platter or enything metal.
They come with a plug converter thing and use the neutral as a earth so make sure its the right way or replace with a proper plug, or enything thats earthed is now live. |
This account is used by 2 people. |
ultrascan
New Member Joined: 06 December 2015 Location: rochester Status: Offline Points: 1 |
Hi all
No display is usually caused by ZD903, it is a surface mount diode on the underside of the power supply board, a tiny little thing, this is a 2.4 volt zener diode, care is required when removing it, but you can fit a real 2.4 volt zener diode on the underside of the board, the cathode is to the right with the diode position closest to you, I used a 2.6 volt as that is what I had to hand working no problems.good luck and don't forget to disconnect the unit from the mains supply before working on it, or you will have problems also make a note of the direction of the ribbon cables checking on what side the blue bit is before disconnecting them, it will save you a lot of time and trouble. good luck, kr Pete Edited by ultrascan - 06 December 2015 at 12:38am |
Nomakon
New Member Joined: 05 October 2019 Location: Argentina Status: Offline Points: 1 |
FIXED I PUT A DIODE Zenner 1n5221 1/4w non SMD adapt the DIODE. Works correctly.
