  New Posts New Posts RSS Feed - Denon DRA 800 H
Denon DRA 800 H
HighnessComity View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HighnessComity Quote  Post ReplyReply Direct Link To This Post Topic: Denon DRA 800 H
    Posted: 20 February 2024 at 9:32am
Can I connect a 4 ohm and an 8 ohm speaker, and parallel to the left channel. And do the same for the right channel. Or will this cause issues with my receiver. The receiver in question is a Denon DRA 800 H
BrainlessTekno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrainlessTekno Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2024 at 9:48am
i believe the recomended ohms on DRA 800 is 4 to 16 ohms, when you put 4 and 8ohms in paralel you get 2.67ohms (less than 4). So i would not do it.
BarSick / barsik soundsystem
Dont want to toot my own horn but toot toot
Lucasdude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lucasdude Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2024 at 11:35am
Specs for that receiver are not good with low impendence. 2x100w @8ohms 20-20, but only 2x120w @6ohms 1khz. No figures given for 4ohm operation, so I doubt it will perform well unless at low volume.
