  New Posts New Posts RSS Feed - Designing a dance stack..
Topic ClosedDesigning a dance stack..
 Post Reply Post Reply Page  123 53>
efinque View Drop Down
Direct Link To This Post Topic: Designing a dance stack..
    Posted: 15 September 2017 at 10:08am
Sup Speakerplans forum,
I thought I'd post this here too for additional advice.
Presumably most of you already know what a dance stack is... anyway, I've been designing these over the course of years but due to lack of resources I haven't been able to build one.
As for some background info; I've built a 15" scoop, and a 186/1850 which we couldn't get functioning due to the driver being broken.
Originally posted on DJF (link to thread)
Any thoughts?
Thanks in advance,
-ef
bob4 View Drop Down
Direct Link To This Post Posted: 15 September 2017 at 10:38am
Frankly that stack doesnt make much sense. Two different types of frontloaded bass horn, and then a scoop, what would be the reasoning behind this contraption?
bob4 View Drop Down
Direct Link To This Post Posted: 15 September 2017 at 10:41am
Crossover points make no sense either. Why have a scoop if you plan to play it only 250hz and up? 😐
Direct Link To This Post Posted: 15 September 2017 at 11:20am
Direct Link To This Post Posted: 15 September 2017 at 11:32am
Ehm.. that's a good point which I didn't take into account.
But scoops really do well in the midrange. (edit : sorry)
Those can be fine-tuned later on. And in my experience scoops require a substantial amount of power in the low range. But I did make an anecdote in DJF about notch filtering the scoop to make it omit the "punch" range (50-150Hz) which is sort of experimental but worth trying I guess.
Edited by efinque - 15 September 2017 at 11:37am
bob4 View Drop Down
Direct Link To This Post Posted: 15 September 2017 at 11:49am
No offense, but the way you have planned your stack suggests that you don't fully understand how and why this type of stacks are designed. Putting random boxes in a heap will not magically yield a working dance stack. Each box is a well thought compromise that is designed to work in synergy with the rest of the stack.
Maybe read some more and go back to the drawing board again after a few months?
Direct Link To This Post Posted: 15 September 2017 at 12:02pm
Then of course there's the Funktion One Dance Stack-range which offers a very similar solution (4-way system with 2 types of bass bins) but from what I've gathered they're pricey, around 50-100k depending on the setup.
I calculated that this system could be built for, say, 10k..
EDIT : And I did consider the lens horn too but their availability is, should I say, questionable.
Edited by efinque - 15 September 2017 at 12:03pm
Risc_Terilia View Drop Down
Direct Link To This Post Posted: 15 September 2017 at 12:32pm
Scoops do not do really well in the midrange.  Something like a MT121 12" horn will be suitable here.
Edited by Risc_Terilia - 15 September 2017 at 12:47pm
cravings View Drop Down
Direct Link To This Post Posted: 15 September 2017 at 12:33pm
bob4 is right. and what you have come up with has pretty much no similarity to a fk1 dance stack.
Direct Link To This Post Posted: 15 September 2017 at 12:50pm
Er, I don't see anywhere that F1 was mentioned - the design is clearly influenced by the original RLA / GSA style dance stacks, with rear-loaded mid-range horns and FLH subs.
Direct Link To This Post Posted: 15 September 2017 at 1:02pm
Direct Link To This Post Posted: 15 September 2017 at 1:50pm
Yes, it's true that the stack concept is pretty much copied from the aforementioned companies. The bottom-end sub is basically a modified W-Bin (I have the plans somewhere..)
