  New Posts New Posts RSS Feed - differences between 186/1850 horn with same driver
hdk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hdk Quote  Post ReplyReply Direct Link To This Post Topic: differences between 186/1850 horn with same driver
    Posted: 16 March 2010 at 10:28am
Hello there,
it is really difference in sound between these two horns ? top is 186, bottom is 1850. As you see, there is only few changes between project. Do you think that if I would put 1850 speaker to 186 horn it will sound that same like in 1850 horn ? Or these plans are so precise?
I ask because we built 1850 horn, and put there RCF LF18N401 driver, and I wondering if it make difference in sound when we would build 186 horn and put there these RCF.
One big disadvantage of these project is weight. About 80 kilos/one... uhhh
P.S. Here you have some mobile-camera photos from building days (2x 1850 and 2x X12):
http://www.caffeine.pl/discordia/diy_soundsystem/
DjJosh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjJosh Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2010 at 1:16pm
186 is more musical and softer sound. 1850 is very honky hard sound, and need stack at least 4cabs and 1850 need some strong draivers. READ http://www.speakerplans.com/index.php?id=faq
Wrighty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2010 at 4:53pm
The chamber size is the main difference and has an effect on frequency response and cone excursion.
High BL driver (strong motor) like the PD.1850 = small chamber.
Lower BL driver like the PD.186 = large chamber.
BL somewhere in between, like the Eighteensound 18LW1400 = medium chamber.
ALL YOUR BASS ARE BELONG TO US.
