different coloured RAM slots |
Page 123> |
tweeter box
Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
Topic: different coloured RAM slotsPosted: 06 September 2010 at 3:50pm |
why they like this on motherboards??
LondonTowers
Joined: 23 July 2010 Location: Colchester,Esse Status: Offline Points: 281 |
Posted: 06 September 2010 at 4:54pm |
on modern boards they generally tend to relate to dual or tripple channel mode.
IE on my mobo, i have 2x green (channel A) and 2x orange (channel B) sockets (dimms)
if you for instance buy a dual chanel memory kit of 2x sticks of 2gb, your first stick would go into the lowest DIMM on channel A, and the second stick would go in the lowest DIMM of channel B, EG
DIMM 1 (Chan A) <-- 1st stick
DIMM 2 (Chan A)
DIMM 3 (Chan B) <-- 2nd stick
DIMM 4 (Chan B)
in this scenario dimm2 and dimm4 would be left empty, and if you have a second dual channel memory kit, youd put them in there.
thats normally the case for different colored sockets, it can differ, if you post the mother board make and model# ill check it out for you.
Of course with a tripple channel motherboard youd have the following arrangement
DIMM1 (Chan A)
DIMM2 (Chan A)
DIMM3 (Chan B)
DIMM4 (Chan B)
DIMM5 (Chan C)
DIMM6 (Chan C)
and you would insert your memory as before, but it would be three sticks so youd use dimm1,3 and 5 :)
hope this helps :D
tweeter box
Posted: 06 September 2010 at 6:57pm |
cheers for the explanation, mine must be dual channel then
ive got 2 stick that are the same and another 2 sticks which are slightly diff, will this matter?
will put up mobo details tomorrow
JohnnyPyro
Joined: 17 November 2008 Location: London Status: Offline Points: 2072 |
Posted: 06 September 2010 at 7:04pm |
always best to have the same memory but as long as you have 2 pairs that are matching it wont make much diff on a normal pc ... but put 1 pair in slot 1&3 and the other pair in slot 2&4
Powered by MC2 & XTA |
tweeter box
Posted: 06 September 2010 at 7:11pm |
cheers for that, read somewhere bout setting the RAM in bios, any ideas bout that?
Edited by tweeter box - 06 September 2010 at 7:11pm |
JohnnyPyro
Posted: 06 September 2010 at 7:21pm |
TBH mate it only really matters if you use a gaming rig and then you would need all 4 matching but from experience pc's tend to run faster on 2 larger dimms of memory rather than 4 smaller
tweeter box
Posted: 06 September 2010 at 7:43pm |
nah not doin gaming, running Traktor of it |
JohnnyPyro
Posted: 06 September 2010 at 11:19pm |
just out of curiosity .. how much ram you putting in and what version of windows as XP only supports upto 4 gig and if you have a graphics card that memory is taken into acount too
audiomik
Joined: 06 April 2010 Location: Bath, UK Status: Offline Points: 2956 |
Posted: 07 September 2010 at 12:32am |
Re: " read somewhere bout setting the RAM in bios, any ideas bout that?"
You should find that the RAM is 'auto detected' by the Bios, however if you change the amount of RAM, the Bios might ask for a re-boot at start-up after the change. Does that with all my PC's
Mik |
Warning! May contain Nuts
plus springs, washers, screws, etc, etc. |
tweeter box
Posted: 07 September 2010 at 10:52am |
ok so ive opened up the PC and here are the mobo & Ram details:
motherboard: ASUS P4P800-VM
ram: 2 x HYNIX HY5DU12822CTP-D43 IN SLOTS DIMM B1 & B2 (B1 = blue, B2 = black)
2 x UNBRANDED (trying to fing info on em now)
tweeter box
Posted: 07 September 2010 at 11:12am |
ok so ive got 2 x sticks of ram that i cant identify, all thats written on the actual module bits is 64x8ddr 9 0921
any help to identify em guys?
audiomik
Posted: 07 September 2010 at 11:54am |
have a look in the Motherboard Manual, if you don't have a copy of this you should be able to download it from the ASUS website, together with any window$ hardware drivers you might need.
Obviously what you have is a DDR type SIMM, what isn't clear is the clock frequency. I suspect that your Motherboard supports DDR2 types though. There is something about the relationship between the '64x8' in terms of it's capacity but can't instantly remember what that is. The Manual will tell you what type of Ram and the clock rates that are supported by your motherboard. So long as the SIMMS fit the sockets and the Motherboard supports DDR then you may be OK to use them. The System Bios should 'auto detect' the RAM clock frequency so you can then find out what 'speed' the RAM you have is. Do check the Motherboard Manual first though! If you are still stuck or uncertain about this then look at: http://www.novatech.co.uk/novatech/prods/components/memory-pcandlaptop/ where you can buy reasonable cost new RAM to match your Motherboard - have found the sales people at Novatech very helpful on the Phone so well worth calling them when you have the MB manual and can tell them what RAM types it says in it. Hope this assists Mik Edited by audiomik - 07 September 2010 at 11:57am |
Page 123> |
