diffrent types of woofer? |
Sencesync
Joined: 17 April 2005 Location: United States Status: Offline Points: 180 |
Topic: diffrent types of woofer?Posted: 17 April 2005 at 3:06pm |
i have one question, im really a fan of Madison woofers. and i have
here a modified version of the 186 horn *so i cant get introuble if i
make more then four on accedent* but i dont want to use anything but
Madison speakers. I'm using Madison Exicutioner X 18" 2,000watt series
woofers for the horns, and i know that thier EBP and BL is is too low
for the 1850 horn, so im using the 186 horn (modified) no really
diffrent in the folded area, its a perma mount box, so you cant realy
change the woofer out of the back. all the empty spaces for example the
top front corner and bottum back corner ares are stuffed with cotten to
get rid of ANY echoing out of thoose chambers (if it ever happens) and
i exstended the vent out shelf, and added two more fins to give it a
unique look. i was going to make a dual tower with it, but its just a
tad small, the hole thing is tho, is how well does anything think the
madison Exicution X 18" will do in there? if you need specs there at
the following site: www.madisonspeakers.com click on raw drivers, and
scroll to the bottum of the page, the ExicutionerX 18" and 18" dual
voice coil and the Exicution X 21" are there
whitehousejamie
Joined: 08 March 2004 Location: United Kingdom Status: Offline Points: 1485 |
Posted: 18 April 2005 at 4:51am |
The Qts of that driver is much too high, you want something around 0.30 for the 186 horn, and 0.20 for the 1850.
