Digi Pro Amp module Fixed!!! |
Post Reply | Page <1 345 |
byronit
New Member Joined: 05 June 2019 Status: Offline Points: 2 |
Thanks for your assistance i have emailed the files as requested. The sub emits a hum possibly the caps are bad , ill will check power supply for ac ripple, any other advise
fmatteo93
New Member Joined: 08 July 2019 Status: Offline Points: 1 |
Good afternoon to everyone.
I also have some issues with my DIGIPRO 600M amplifier. Can I receive the electrical schema? Many thanks, Matteo Falchi
ecoso
New Member Joined: 05 March 2018 Location: devon uk Status: Offline Points: 4 |
Hi, Are you still doing repairs to Digipro amps? I have 2 for you to look at... ed
AudioSystemsEngineer
Registered User Joined: 11 November 2013 Location: London Status: Offline Points: 144 |
Hi, who's successfully repaired Digipro modules ?
I've got a digipro1000 on the bench at the moment, SMPS is GOOD, Output FETs are GOOD. Won't start with the O/P FETs in, No swithching waveforms on the FET gates on either channel. I'm about to replace the IRS20957S drivers but seems a bit odd that i'm getting nothing on both channels, so its possible the shutdown is active. LED 1 and 2 are lit, but their function is not labelled on the board or schematic. any help apreciated :-)
mantasel
New Member Joined: 06 May 2022 Location: Lithuania Status: Offline Points: 3 |
Hi, what could be wrong with Opera 712DX amplifier module? It is from dBtechnologies active speaker. RED LED blinks 7 times and pause, 7 times and thats all... No sound, nothing.. All Mosfets are good, checked, PSU and NTC protection voltages all are OK.. Could be software problem? 24LC256L memory is OK. How to full reset processor, PIC16F689? Could someone repaired it and could Help to me?? https://www.facebook.com/mantaspu/videos/5054032577968008 https://www.facebook.com/photo/?fbid=10220872881747993&set=pob.1118047132 https://www.facebook.com/photo/?fbid=10220872881787994&set=pob.1118047132
voron
Registered User Joined: 05 April 2009 Location: Russia, Tver Status: Offline Points: 165 |
Thanks(1)
Yes, I can fix your amp, even if pic16f689 is damaged. 7 blinks means that adau not loaded from eeprom or damaged
mantasel
And what price for such fix to be about? Do i have to send only PCB board to You or anything else more? What country are You from? Thank for reply ;)
voron
I'm from Russia, Tver. I think the shipping cost will be too much.
VECTORDJ
Young Croc Joined: 11 June 2006 Location: United States Status: Offline Points: 513 |
It should be a Crime to sell Junk that is not Fixable.......CUSTOMER rip-off.....Over and over Customers are having Powered Speakers FAIL......Looking for Someone Who can really repair D-Class Amps in Maine USA......VECTORSONICS
mantasel
Do You have processor and e2p dumps and can to share with me? Maybe schematic also? Thank!
voron
Sorry, I have NDA restrictions.
